Tool Talk Discussion Forum
Vortec tune-up
DCM
08-11-2005 06:00:34
What would be involved other than sparkplugs, it"s a V6 and runs great.Bought it used, dist. cap and wires look good.Just wondering with colder weather in a few months,Dan
xragman
08-12-2005 12:18:45
 Re: Vortec tune-up in reply to DCM, 08-11-2005 06:00:34
like MAC said. don't mess with it. not much you can do for it till something goes wrong;then trouble shoot & fix that.
Big J
08-12-2005 11:07:19
don't forget Dist cap & rotor
Loren
08-11-2005 22:45:29
If you're going to do the wires look at the coil for any grayish/whitish coloration around the frame. If you see that I'd replace it also.
RayP(MI)
08-11-2005 15:05:25
Ignition wires will go bad over time. Even if they look OK, you might want to replace as you approach 100,000 miles. Insulation will break down, and carbon cores tend to break down as well.
dhermesc
08-11-2005 11:23:59
Our construction company runs 13 Chevy half ton 4X2s with the 4.3 V6. I'll second the fuel filter needing changed on a regular basis. The other area that seems to be a common problem is the electric fuel pump - never know its a problem titll it quits. Otherwise we normally run them up to 120K to 160K with very little else being done except oil changes - and even that gets spotty some times.
dhermesc
08-11-2005 11:25:50
 Re: Vortec tune-up in reply to dhermesc, 08-11-2005 11:23:59
The transmission oil gets FLUSHED on a regular basis - haven't had a half ton trannie fail in 5 years. Our mainteance plan does not call for the pan to ever be dropped - just flushed every 50K.
Chris Vangel
08-11-2005 09:12:19
I would change the fuel filter annually. Those trucks are very picky about fuel pressure and the best thing for them is a clean fuel filter. It's on the frame on the drivers side.
MAC,IL
08-11-2005 08:45:16
Depends a lot on the mileage. Maybe change the air filter. Otherwise if it aint broke dont fix it.
