Tool Talk Discussion Forum
Air Compressor
Kevin in OK
08-07-2005 17:03:31
We have a really old air compressor and I was wondering if it was worth anything. On top of the cylinder it says SPEEDY. It is a belt drive, sindle cylinder, on a base that is somewhat oval shaped. Is it sumtin I should be treasuring or are they common? We are going to put it into a garage sale, and I was curious as to a rough value. Thanks
Kevin
Not much help, but
08-13-2005 14:41:55
 Re: Air Compressor in reply to Kevin in OK, 08-07-2005 17:03:31
Looks like a dive compressor for use as a hookah. Shallow water diving, it sends air thru a hose to a regulator and mouth piece. It's an oil free diaphram compressor. May be able to use it as an air supply for a sand blasting hood. That's what I'm trying to set mine up for. Project #975.
shannon from ohio
08-10-2005 01:40:16
Yeah, i got one too,I put a small briggs engine on it being the electric motor was missing.Air pressure is limited on them though.Mine will go to about 50 psi if im lucky.Good for blowing up balloons
old
08-07-2005 19:19:21
I have one of them but its a 2 cylinder one. Just sits in my shop and does nothing since I don't need it for any thing but who knows
Slowpoke
08-13-2005 14:44:00
 Re: Air Compressor in reply to old, 08-07-2005 19:19:21
Now you know.
Kevin in OK
08-07-2005 18:36:39
 Picture in reply to Kevin in OK, 08-07-2005 17:03:31
third party image
Heres a picture of the compressor if it helps any.
Kevin
