Tool Talk Discussion Forum
Air compressor motor problems, advice please..
Jay87T
08-07-2005 06:22:32
Hey guys my air compressor motor started smoking and then there was a buzz to it, it spins freely its not seiezed or nothing but everytime I plug it in I just hear the BUZZ. could it be the start capacitor? if so has anyone ever changed it themselves here?
Jay.
Bus Driver
08-07-2005 11:03:07
 Re: Air compressor motor problems, advice please.. in reply to Jay87T, 08-07-2005 06:22:32
Remove the drive belt. Spin the motor by hand and turn on the power while the motor is still rotating. If it runs, first try a new capacitor. If it then runs normally, reinstall the belt and test run it. If it does not run normally after capacitor replacement, either the start switch or the start windings are defective.
KENT
08-07-2005 10:08:16
ALSO, MAKE SURE THAT YOU HAVEN'T LOST ONE LEG IF IT'S 220V
XXXRogerXXX
08-07-2005 09:42:06
If it has capacitors, pull off the cover and look at them. A bad capacitor creates the symptoms you describe, a loud hum with no movement. Usually, the contacts on the ends break off from vibration after x number of years. The starting switch is also a good place to check, but capacitors are easier to get at and more likely to be the problem. Make sure they are discharged before you start pulling wires!
Bernoulli
08-07-2005 07:45:19
I've been told that the smoke is put into the motors by the manufacturers. If you let it out; it's a goner.
buickanddeere
08-07-2005 06:54:30
The mechanical starter switch that open the contacts supplying the start windings. It's likely stuck in the "start" position. Odds are now that it "smoked", those start windings are burned open. Even freeing up the start switch won't save it now.
Jay87T
08-07-2005 07:26:35
 Re: Air compressor motor problems, advice please.. in reply to buickanddeere, 08-07-2005 06:54:30
yeah I think its shot...spins freely but nothing just a buzz, looks like Im shopping for a new motor.
buickanddeere
08-07-2005 10:14:42
 Re: Air compressor motor problems, advice please.. in reply to Jay87T, 08-07-2005 07:26:35
Take an ohm meter and check the start windings. They should be in the 10's of ohms. The main run windings will be a few ohms. If the start windings are open. All the motor is good for is either a door stop or an induction generator. Make certain to purchase the robustly built compressor motors. If your compressor doesn't have an unloader for start up she needs one. Check start and run voltages. There maybe a cause for the smoke leaking out.
