Tool Talk Discussion Forum
OT pluged water well screen
mlm
08-06-2005 19:32:06
last time it cost $700 to have the pipe pulled and the screen cleaned. the well is a deep well packer style.the pump is a 1/2 hp above ground. He cleaned the stainless screen with muratic acid.
why can't the screen be left off? if the grit wears the pump out,i can get a used pump for $50. the labor to replace a woren out jet would not be any greater.he did not seem to want to leave the screen out. also I have heard of people pumping acid down to clean things. will this work?
paul
08-07-2005 20:49:22
 Re: OT pluged water well screen in reply to mlm, 08-06-2005 19:32:06
I have a 37 year old 260 foot deep well, submursable pump. In sand, screen is down there. Had the same problem this spring, for $1400 they pulled the pump, put down 13 gallons of buffered acid over 2 days, sloshed it out, & got it working again. Was lucky, if there is a hole eaten in the well casing the sand comes in & time for a new well- $10,000 or so.
Before I was around we had a deep well where the screen went bad. Guess they tried it without the screens. Two pumps shot in 3 months time. Just not a worthwhile option....
Your milage may vary, how it is here.
--->Paul
Richard H.
08-07-2005 06:01:12
I started a thread over on tractor talk an got some good advise, "Well ideas please" Richard H.
