Tom, I recently purchased a Craftsman 110-volt MIG welder and basic accessories for around $450. I hadn't done any welding since taking a metal working class in college. There I learned a few basics in arc and oxyacetylene welding. With this MIG welder I found making excellent welds on mild steel simple. MIG welders can weld steel, stainless steel, aluminum, copper, and brass. The required skill level is low... shortest learning curve. The MIG welder is a continuous line feed arc-welding process. All you have to do is pull the trigger and as long as the line fed metal wire is touching the grounded metal surface welding. Like "stick" arc welding, you must wear the proper eye protection. It can be a little scary the first few time because the eye protection lenses are so dark you can't see anything until you touch the metal creating the ultra-bright arc. MIG welding is much cleaner than stick welding. Typical MIG welders use an Argon/CO2 gas. You can however purchase flux core wire line that does not require the gas. The one drawback I have with my MIG is the cycle (or duty) time. Cycle time is the max working time per 10 minutes. My MIG has a 20% cycle time, thus I can work for 2 minutes and then I have to let it relax for 8 minutes. I'm looking into a $1400 220-volt Millermatic 185 MIG that runs more efficiently. Hobart and Miller are two very good brands. I believe the Craftsman I bought is made by Century. I have no major complaints with this Craftsman. It was an impulse buy. I tend to think I would have a warmer fuzzy feeling if I had a Miller. Some accessories/metal working tools I found I needed are: 1) Argon/CO2 tank. Initial tank and gas is $75-125. Refills are $15-30. 2) Porter-Cable 4-1/2" Angle grinder $95 3) Porter-Cable metal Drycut chop saw $450 (Abrasion saws are far less expensive. All I know is the drycut saw makes incredibly perfect cuts with no burrs and the metal remains cool.) 4) I will be buying a "auto-dimming" welding helmet soon ($130-270). The lens varies the shade darkness as you weld. There's no need to remove the helmet to see when not welding. The lens is see through with normal light, then instantaneously darkens when an arc is detected. Good luck, Chris
