Tool Talk Discussion Forum
Yellow jackets
JimDR
08-02-2005 15:57:05
Went to get plank out of a shed and was attacked by a swarm of yellowjackets. I got away with only 3 or 4 stings. But the bad news is I need a couple planks out of there in a week or so. Seems to me I read something about making a poison trap for these little buggers but can't remember the details. I'd spray their nest but its somewhere in a pile of 2 x 6s. Every year I have a run-in with them.
Dave_Id
08-04-2005 14:52:26
 Re: Yellow jackets in reply to JimDR, 08-02-2005 15:57:05
Spray your whole shed with gasoline, then when they crawl out of their hole, stab them one at a time with an ice pick. Remember, you don't want to smoke while doing this.
3010 Ken
08-04-2005 06:46:01
Morning Jim;Seems as though we've had more than our usual share of wasps and hornets this year also.My son was weed whacking around our pond a couple of weeeks ago and found a nest in the levee.A few weeks before that he was using my old push mower on the same levee and got into them.Only thing is,he did'nt pull the mower back far enough before he took off running and it ended up in about 10 ft. of water.I don't care about the mower,we drained all the fluids and got her back running in a few minutes,seems to run a little better after that bath!Anyway, we use about a pint of gasoline poured right down there hole and leave the bottle or jar covering the opening so the fumes can do there work.Good Luck. Kenny
Rod in Smiths Falls, ON,
08-04-2005 13:06:42
 Re: Yellow jackets in reply to 3010 Ken, 08-04-2005 06:46:01
When you are high in a mow full of last year's straw, one thing you don't want to find is HALF a hornet's nest in the bale you are lifting...
At the hospital they quit counting the stings at 80, with some still falling out of my hair, armpits and beard.
RusselAZ
08-03-2005 20:23:53
For your personnel protection while approaching the nest have a big can of that spray adhesive with you. Any flying ones will crash and burn when the mist hits their wings and antenna.
A wet and dry vacuum with about a half load of real soapy water in it works well on a cool nite. I have never had any experience with nest in the ground. For good long term trapping the glass jars that have the one way lids for yellow jackets work well. Even here in the desert they catch a lot of wasp. Just takes a little raw meat in the jar to get them started.
ErnieDD
08-03-2005 15:11:18
Tape a length of conduit to the nozzle of bug spray and use that extension to direct spray to entrance of nest.
RayP(MI)
08-03-2005 13:29:05
If you can find where their hole is, and leave a piece of cardboard in such a position that they will use it for a landing strip, then put a couple drops of Terro ant killer on the cardboard. You may have to renew Terro couple three times over a week or so. They'll suck up the poison and take it into the nest, and poison the rest of the colony.
Joe MD
08-03-2005 12:30:42
Funniest thing I have seen all year.
My brother in law walks close to the diving board at our pool. I tell him careful, there is a big wasp nest underneath.
What does he do? He kicks the diving board. "Oh, yeh look at all of them," he says as he walks right up to the corner where the nest is. Bam, Bam, Bam gets stung like crazy.
After he sprays the nest, his excuse was that "he wanted to give the wasps a fair fight"
I wouldn't use gas 'cause of all this mtbe nonsense.
Bernoulli
08-03-2005 11:07:33
Traps probably won't work. There are too many of them. But here's how you make one: Fill a bucket to within a couple of inches from the top with water. Float some vegetable oil on top to cover surface. Suspend meat (fish works well) over water an inch or less. The yellowjackets will cut off a piece of meat. When they start their takeoff, the weight of the meat makes them fall in the oil and they can't get out.
A more effective way (there are thousands in the nest) is to follow them at dusk and find the entrance to their nest. It will be a small hole, less than 1/2" in diameter. Pour a pint of gas down the hole after dark or use Miller's Whack (if it's still available. Doesn't take much and it is specific to wasps and hornets.
Big Marv1085
08-03-2005 05:19:13
I would go in the shed and look for the bees to leave and return to the nest. Be careful not to disturbe them until they have been located. Then go in a night and pour some gas or seven in the hole.
DaveL
08-03-2005 03:44:08
I have the same problem with ground hornets here in north Florida. The problem is they are in nests around one of my lakes and I can't use pesticides because of toxicity to my fish. I found these guys while weed wacking!!. Anyone have any ideas other than boilibg water?
Tyler in CT
08-06-2005 10:42:10
 Re: Yellow jackets in reply to DaveL, 08-03-2005 03:44:08
I have had sucess getting rid of a yellow jackets nest by putting a bug zapper over the entrance of the hive and sealing around the edge with a couple scoops of dirt. Its kinda fun to watch em come out of the ground and ZAP!!. Only drawback is that it takes a long time to kill the hive. Took about two weeks because of the brood hatching in the nest. Its safe for the fish because no chemicals are used. Give it a try.
Nolan
08-04-2005 04:00:19
Sevin doesn't kill fish.
Tyler in CT
08-06-2005 10:44:45
 Re: Yellow jackets in reply to Nolan, 08-04-2005 04:00:19
Yeah I'm sure its real healthy for them.
Nolan
08-09-2005 03:03:14
 Re: Yellow jackets in reply to Tyler in CT, 08-06-2005 10:44:45
As the old saying goes, better to be silent and be thought a fool than to speak and remove all doubt.
It's hard on shellfish, not vertibrates. Amazing what you can learn with a little research.
DaveL
08-06-2005 12:00:05
I think my best bet is waiting for the weather to cool down here and continue weeding around my lakes. I would be hesitant to try Sevin near the water.
Boy, one of those hydraulic mower arms that go out the side of your tractor would be nice!!!!
Nolan
08-03-2005 03:13:33
One of my sideline businesses is wasp extermination. It's generally not hard.
My favorate spray is Spectracide. The green can stuff you see at Home Depot and such. By far, it's one of the best I've found currently on the market. I use it on aerial nests. My best brag about it would be attacking a bald faced hornets nest from directly below on a ladder about 20 feet up, no bee suit on. The hornets were flying out, and falling all over me, dead and dying. I didn't get stung.
My favorite ground treatment is Sevin. Powder the hole and the area immediately around it. Place a board over the entrance so the critters have to walk through the powder. The nest will be dead in a few days. I only do this on my own nests, because it's lazy and easy. For commercial customers, I dig nests out which necessitates suiting up and spraying. That's a pain and I don't recommend it for you.
Work at night by flashlight. They *generally* don't fly. Don't mistake that for they can't fly or won't fly. And they are quite capable of walking up your legs to sting you. So work quickly, smoothly and with as little light as you can.
Chris in Md.
08-03-2005 01:55:44
The reason to locate and attack any bee at night is that they are not active at night. That doesn't mean they won't sting at night- don't ask me how I know this. Further, all of the bees are in the nest at night. If you approach carefully after dark you may be able to locate the nest. If you can locate the nest a safe way to kill them is Sevin in dust form made by Ortho. If you can spray
the nest or an entry to it with Sevin they should all be dead in 24 hours or so. Good luck.
Tom in TN
08-02-2005 19:15:04
Jim,
I don't have much experience with yellow jackets, but I have lots of wasps around my place. Some are black, some are red, some are blue, some are black and yellow. I use Raid or Black Flag wasp and hornet spray on them. Man, it knocks them right out of the air, they fall to the ground and die immediately. The residue is supposed to kill returning wasps, but I don't think it really works all that well.
My local Co-op also carries an insecticide that they call "Demon". I don't know what is in it, but it also wipes the wasps out.
So, if you haven't already tried it, you might try one can of wasp & hornet spray to see if it gives any good results.
Good luck,
Tom in TN
old
08-02-2005 17:58:06
If it in a place that you can pur say a gallion of gas on them after dark that will fix them. Then just go back in abd hour of so and pull the plakes out. They don't do well after dark and the gas will kill them fast. Just glad it wasn't me I might have ended up in the hospital, LOL
FarmerDave
08-02-2005 17:16:59
You ought to be minding your own business weed wacking and find their ground nest. Yikes!!!
I've see YJ traps at the farm store by the fly control stuff. You'll need to go to the better farm store.
I don't think they can see in the dark, but test them at your own risk.
youngster
08-02-2005 17:13:22
good way to get them planks out and not get stung is to find some do gooder with alot of free time to go get em out for ya then give em 5 bucks or so.
Steve (Magnolia, TX)
08-03-2005 06:07:37
 Re: Yellow jackets in reply to youngster, 08-02-2005 17:13:22
ROFLMAO!!!
This is the best response I've seen, so far!!
Steve
Coldiron
08-02-2005 16:29:47
Jim, Do a google on "homemade wasp trap" and it will kick up a lot of different ways to get rid of them. You could wait till it is dark and go back into the shed with a flashlight to find the nest. Use the 20 foot type aerosol spray can to reach out and get them. Look around and you may find more than one nest. Sometimes their nests are hidden. I found one today in a covered outdoor electrical outlet. Ran faster than I should for 64. LOL gonna get them tonight though.
txgrn
08-05-2005 04:34:48
 Re: Yellow jackets in reply to Coldiron, 08-02-2005 16:29:47
I tried that on a nest of bumble bees....waiting till after dark and got hit twice from the rear B4 I knew what hit me. Had sentry's posted somewhere. And if you haven't been hit lately, they hurt.
Mark
Coldiron
08-05-2005 07:53:00
 Re: Yellow jackets in reply to txgrn, 08-05-2005 04:34:48
Got hit this morning by two hornets. They had a softball sized nest started on the south side of the house I wasn`t aware of. Got rid of them with the foaming stuff from 10 ft away. Those buggers can put the hurt to you enough to make you run like a teenager. Going to go out afterwhile and knock it down and squish it flat so the eggs can`t hatch. LOL
Mark - IN.
08-02-2005 18:03:08
Could do a Google on "Killing yellow jacket bees" too. I still blew them up. Left a crater in the ground a couple of feet in diameter and over a foot deep. I would've done what they said, but was this last Sunday, I couldn't get the chemicals I needed over the counter to spray and dust (poison) them, had to leave Indiana for Illinois, and next weekend need to get to that fire wood unimpeded. I just flat out blew them to smitherines, but was in a pasture, so nothing else got blown up with them and their nest.
AND no matter what anyone does, do it after dusk when they've settled in for the night, otherwise buzz, buzz, buzz, YOUCH, YOUCH, YOUCH.
Mark
Maine Fordson
08-03-2005 06:21:07
 Go after them at night in reply to Mark - IN., 08-02-2005 18:03:08
Just in case you decide to go after them at night, here's a hint from an old beekeeper: Put a red lens on your flashlight. They can't see in that spectrum -- we used to have red lamps in the hot-room where we stored the honey before extracting it.
