Tool Talk Discussion Forum
Tilting Trailer - Pics
Ryan - WI
08-02-2005 15:10:25
third party image
Here are three pics of the tilting trailer. I can not see how you would be able to lift much of anything heavy as the cylinders mount so low, I wouldn't think they would get much leverage. As far as using it to unload hey/logs/pipe etc by rolling how on earth would you control it as it fell the 3 feet to the ground? I would think that would be dangerous as heck.
Ryan - WI
08-03-2005 11:16:29
 The answer is in in reply to Ryan - WI, 08-02-2005 15:10:25
According to Kathy at Davis Welding...
"We started building those trailers at the request of all our hay brokers. The trailer is built specifically to dump off round or square bales once they have reached they're intended destination. It can also be used for hauling tractors, equipment, etc., but the side dump feature is for dumping bales."
I still think it would make an awful mess.
Jae
08-04-2005 07:31:34
 Re: The answer is in in reply to Ryan - WI, 08-03-2005 11:16:29
Link
Similar set up as this trailer
paul
08-03-2005 23:08:23
Not really.
What you save is having to own a second tractor/ big Bobcat with a loader & bale spear.
That is a lot of savings.
Load up your Bobcat, drive to the hay field, load, haul the load home, dump, come back. Repeat.
When you get done, load the Bobcat, come home, & stack them away.
Or, if you sell hay, you dump & leave. No need to wait (and wait) while someone unloads your trailer, & bangs into it or the floor a few times. Dump & go, no time wasted.
--->Paul
Mike M
08-03-2005 05:11:57
 Re: Tilting Trailer - Pics in reply to Ryan - WI, 08-02-2005 15:10:25
Maybe ? you can mount solar panels on it to power an electric truck ?
Could be made for delivering plastic tile or culvert.
Tim B from MA
08-02-2005 22:21:18
How about for taking really fast right turns? :)
Jerry L ?AZ
08-02-2005 18:13:34
I've seen them used to haul and dump long sections of irragation pipe in the field
Ryan - WI
08-02-2005 16:43:44
Well, I figured the easiest way is to just ask. It is made by a local company called Davis Welding, so I just sent them an email and asked. I will let you guys know what they have to say. If nothing else it sure sparks curiousity.
Mark - IN.
08-02-2005 15:41:32
Maybe it doesn't tilt for normal use as much as it does for display to the drivers driving past on what looks like could be a busy road. Stop in and ask. Frame looks pretty stout. Might be setup for tilting, but nothing comes to mind.
Then again, might be for the loafer whom is supposed to be helping but is snoring up a storm on the bed under that shade tree while you're busting your butt in the heat. Surprise!!!
Mark
old
08-02-2005 15:35:57
That is a set up for unloading lumber, hay etc.
Ryan - WI
08-02-2005 15:14:57
third party image
Back Side
Ryan - WI
08-02-2005 15:12:19
third party image
Front Pic
Jay87T
08-03-2005 03:56:11
 Re: Tilting Trailer - Pics in reply to Ryan - WI, 08-02-2005 15:12:19
Hydrolics seem very small to be lifting anything heavy like logs and what not...am I right???
T_Bone
08-03-2005 06:59:59
 Re: Tilting Trailer - Pics in reply to Jay87T, 08-03-2005 03:56:11
Hi Ryan,
From what I see the bed will twist with-in the first couple of weighed lifts and never lay flat again. The hydraulics are located wrong and they won't lift much bed weight. Good call Jay.
I was thinking of the same side tilt for dumping manure for the garden but not made the way they made there's. A sub-frame dump body that sits on the flatbed with the dump bed attached to the sub-frame. Dump bed with removeable side & end rails.
I'm pretty sure with out ground supports on the main frame, that it would twist the main frame at some point in time if you had alot of load weight. I think a different design would work alot better and why reinvent the standard dump bed?
T_Bone
