Tool Talk Discussion Forum
What on Earth would you use a trailer like this fo
Ryan - WI
08-01-2005 20:12:25
My wife and I were on our way home tonight and drove by a display model of a trailer for a local company. It is a flatbed gooseneck with hydraulic tilt. Only problem is... the deck tilts to the side. There is apparently a hinge on the right side and the bed tilts up to roughly 40 degrees. Only thing I can think of is a really quick way to unload your tractors. Anyone have any thoughts as to why you would actually want this feature on a trailer? I can get a pic if it helps.
Kent in NB
08-05-2005 04:14:43
 Re: What on Earth would you use a trailer like thi in reply to Ryan - WI, 08-01-2005 20:12:25
Sugarbeet dumper.
msb
08-03-2005 14:06:03
I could have used a trailer like that a long time ago to dump off some blind dates.HEAVY DUTY!
xragman
08-02-2005 13:55:48
maybe some of our english brothern will tell us. I believe they use this design a lot.
2M
08-02-2005 09:48:11
This trailer wouldent happen to be sitting on the south side of Monroe along 69? There is one there that I have had the same question about. I had thought it would be handy for unloading firewood.
Ryan - WI
08-02-2005 15:04:13
 Re: What on Earth would you use a trailer like thi in reply to 2M, 08-02-2005 09:48:11
It sure is.
Vern-MI
08-02-2005 06:06:13
Did it look like it was for farm use? It could have been designed that way to handle extra wide loads that when tilted present a narrower width. Some of the big hydroplane trailers are built that way because of the wide stance of the hull and the sponsons.
Johnski
08-02-2005 02:28:57
I believe that kind of trailer was specially designed to haul one kind of tractor, the ETD or Essex Tri-Directional. You actually loaded it flat and tied it down then tilted the whole mess to disable the tri-directional drive units gyroscopic mass damper. I can"t say any more as most of these units were bought up by the government back in the 50"s. ;>) JF
Tim B from MA
08-01-2005 21:50:51
Unloading logs or pipes; with a couple of ramps it might even be done in a controlled manner.
Ludwig
08-02-2005 10:18:11
 Re: What on Earth would you use a trailer like thi in reply to Tim B from MA, 08-01-2005 21:50:51
Ding ding ding!
Log trailer, I've seen several like that.
Van in AR
08-01-2005 21:40:05
Its a combination trailer, used as a flat bed and a round bale hauler, very smart idea, just don't run the lift with your equipment loaded.
Van
old
08-01-2005 20:19:06
A picture would be a big help
maybe?
08-01-2005 20:36:52
 Re: What on Earth would you use a trailer like thi in reply to old, 08-01-2005 20:19:06
Might be for unloading hay?
