Tool Talk Discussion Forum
Cockshutt tractor.{ring gear for fly wheel}
Ross Toole
08-01-2005 17:50:46
Looking to buy a ring gear for fly wheel has 540 cockshutt tractor has a continnental motor 4 cylender
Ross Toole
08-02-2005 06:34:48
 Re: Cockshutt tractor.{ring gear for fly wheel} in reply to Ross Toole, 08-01-2005 17:50:46
I wish i could use it but it is in to bad of shape and will need to get replaced.Does anyone know where to find one.
msb
08-01-2005 18:56:34
If it isn't broken,heat it and remove it .Give it a quarter turn and quickly reinstall it.Engines always stop in the same two places on a 4 cylinder engine.Throw some cold water on it when reinstalling it.The water will shrink it tight again.
Slowpoke
08-01-2005 23:45:32
 Re: Cockshutt tractor.{ring gear for fly wheel} in reply to msb, 08-01-2005 18:56:34
Not being too experienced with flywheels, is there any reason it can't be unbolted and turned a 1/4 turn?
msb
08-02-2005 09:38:16
 Re: Cockshutt tractor.{ring gear for fly wheel} in reply to Slowpoke, 08-01-2005 23:45:32
Only if its bolted on and most are pressed on with only the press fit keeping it in place.
Slowpoke
08-02-2005 23:38:58
 Re: Cockshutt tractor.{ring gear for fly wheel} in reply to msb, 08-02-2005 09:38:16
I was thinking of the crankshaft bolt pattern.
msb
08-03-2005 14:03:25
 Re: Cockshutt tractor.{ring gear for fly wheel} in reply to Slowpoke, 08-02-2005 23:38:58
On some really bad ring gears reverse the sides if the edges are cut to allow the starter drive to engage the gear.Some gear teeth are beveled and some are not.I have no idea about a Cockshutt.
