Wood splitter using a hydraulic pump from a Ford tractor
Dave
01-19-2001 12:49:51
I have seen plans for a wood splitter using a hydraulic pump from a Ford tractor. Any additional info would be appreciated.
jeff
01-22-2001 15:37:41
 Re: wood splitter using a hydraulic pump from a Ford tractor in reply to Dave, 01-19-2001 12:49:51
I would love to see the plans! Or at least an idea of how to do it. thanks jeff
matthew
03-02-2001 12:07:34
 Re: Re: wood splitter using a hydraulic pump from a Ford tractor in reply to jeff, 01-22-2001 15:37:41
Here are some plans that i found online.. Link
-m>Link
Greg D.
01-20-2001 17:48:16
You will need an open center control valve to activate the cylinder. I believe most of them they push for a log splitter operation have a detent on them so you don`t have to hold the handle. It will be a two way valve with neutral in the center position. I would also recommend a relief valve so as not to rely on the machine relief valve as you will be running a seperate system. If the original relief valve is in the tractor control valve you will have to have a relief valve installed. Make sure if you use quick connect couplings that they will be rated for the pressure and flow required for the system. Same for the hoses, make sure they will be rated for the system flow and pressure.
