Tool Talk Discussion Forum
need advise on brand/type of mower for use of 5 ac
mech187
07-27-2005 21:48:33
Guys, looking for suggestions on what to buy. Got a house on about 5.3 acres. Triangular shaped lot at end of circle in cul-de-sac. Slopes from wide area at back to narrow at front about 5 feet drop.
Pretty steep slope around front and both sides of house due to dirt filled in to allow for view out basement in back looking uphill. Will probably just mow the front, sides and a little of the back on a regular basis approx 2 acres? But need to be able to do the whole place maybe twice a year. Do I need a regular riding mower with the widest cut I can get or would a zero turn work on this type of terrain? Will need to buy used for now. Suggestions on brand and type?
JT
07-31-2005 12:13:29
 Re: need advise on brand/type of mower for use of in reply to mech187, 07-27-2005 21:48:33
Mow 7 acres and trim around 300 trees and about a mile of 30' road ditches with 2 60" Dixie Choppers, take about 3 hours, used to use 2 tractors with a 50" and 60" took 9 hours. So, my vote is for Dixie Choppers, they are probably one of the heaviest built units on the market and they are the only ones who can actually pull 2000# and not void the warranty or destroy the hydro units. Have a lifetime frame warranty. Probably 2 of the ones that have a good name, but have some problems are Exmark and Toro, the rest mentioned are all top quality mowers.
Cliff Neubauer
07-28-2005 15:44:09
We went from using an IH Cub low-boy 185 tractor with a 60" belly mower to a Cub Cadet 3660 commercial duty zero turn mower with a 60" deck and a 25hp engine. My goal with the ZTR was to cut down on our mowing time but it actually takes longer now, it takes about half as long to mow what we were mowing before but with the ZTR we've found we are mowing about three times as much as we were before because it's fun to use and it's almost as fast to use as a pull type mower behind a tractor. We've put 57 hours on our 3660 so far this year but we are mowing 3-5 acres a week with it. The homeowner grade Cub Cadet ZTR mowers are built cheap but their commercial mowers are as good as anything on the market and they actually carry one of the best warrantys in the business.
RANDY
07-29-2005 19:49:11
 Re: need advise on brand/type of mower for use of in reply to Cliff Neubauer, 07-28-2005 15:44:09
I HAVE A 6FOOT KING KUTTER BRAND IVE HAD IT FOR 6YEARS AND IT BEEN A GOOD ONE NO PROBS WHITH IT
IT IS A 3PONIT HITCH TYPE
I USE A NEWHOLLAND 3930 TO PULL IT CUT WELL
YOU CAN GET THEM A TRACTOR SUPPLY $1.300
lucasss
07-28-2005 13:13:59
i have the woods zero turn 61inch cut , it has the deck out front ,looks just like the grasshopper. it does very well on hills . its kind of a stretched out wide design.lucas
youngster
07-28-2005 12:02:27
AT my parents house they have a little over two acres of hilly treed up land that is well difficult at best to mow. my father insistes on always using a cub cadet garden tractor. not relly a problem to mow the grass with, i counted one day close to 250 things to mow around in the yard. and lots of roots it takes me about 4 hours to mow it it takes dad 6 or 8. On the othere hand i worked for a guy last summer who had a zero turn mower well actually a couple, man oh man was that slick works better than a garden tractor on smooth yard anyday hands down. they use them in the cemetery across the street where it drops probibly 4 foot for every 6 foot in length so they take the hills
MAC,IL
07-28-2005 06:21:27
No. 1 son really likes his Grasshopper front deck.
Everything on the deck is really accessible. Tips up for easy acdess.
Stickler
07-28-2005 17:46:22
 Re: need advise on brand/type of mower for use of in reply to MAC,IL, 07-28-2005 06:21:27
I like my grasshopper too. I mow about 8 acres of heavily treed yard site and about another 5 acres of blue spruce windbreak trees.Took my weekly mowing down from about 24 hours to 8. That's around each and every tree.
Charles (in GA)
07-28-2005 05:41:57
You don't say if you have trees or not. In any case, once you try a zero turn mower, you will never, ever again, want to use a regular riding mower.
Zero turns are fast and you can easily work close to stuff without backing and repositioning. If you do need to back and turn, its just the flick of the levers.
If some of the areas you will be mowing are semi rough, the grass being sparse and having twigs and leaves or pinestraw and simply just needs cleaning up a couple of times a year, you want the heavy deck of a true commercial mower to handle the extra bashing it will take.
I messed with cheap riding mowers for my measly 3 acres and finally realized I could buy one, virtually unbreakable commercial mower that would last the rest of my life if I took care of it.
I spent $7000 and bought a 25 hp Kohler, 52 inch deck zero turn and love it. Wouldn't have anything else.
There are numerous brands on the market, Scag, Great Dane, Toro, Dixie Chopper, Gravely, Jacobsen, Land Pride, and a whole bunch more I cannot ever think of right now.
Beware. There is a growing market for comsumer quality zero turn mowers, and many companies who up to now have been making regular tractor type riders have jumped on the bandwagon. Cub Cadet, Aherins (sp), simplicity, and several others. These are cheap, consumer quality units, designed to break and wear out in a few mowing seawons, just like all their other products. If it has a stamped out steel mower deck, its probably a cheap comsumer mower.
I know it sounds crazy to spend $6000 to $8000 for a mower, but the cheap consumer ones are around $2000 now for the higher end (read that as enough horsepower, and big enough deck) and buy three or four of those in your life time and how much have you spent in mowers and repairs ????
Charles
