Tool Talk Discussion Forum
Windowless Air Conditioner ?
TomWNC
07-26-2005 20:10:11
Recently noticed an add for a windowless air conditioner and just wondered if anyone has had any experience with them. I thought an A/C unit had to exhaust hot air, so where does it go with these? And what about condensation?
steve in in
07-27-2005 09:13:43
 Re: Windowless Air Conditioner ? in reply to TomWNC, 07-26-2005 20:10:11
We have one of the portable ones in my wife's office. It is loud. I used some plywood to make a hollow insert to go into the window. Then the hose exited through there. As has already been mentioned, if you don't mind doing it, you can just put a dryer vent in the wall and exhaust through it.
We looked at the mini-split systems too. They are pretty spendy. I still may buy one of those someday. My wife's office is the former "Summer kitchen" in our brick farmhouse. There is not a HVAC system in that part of the house, thus the need for a portable or a mini-split.
Steve Crum
07-27-2005 04:32:11
One of the guys I work with bought one of these a few weeks ago. He said for price and performance, he would not make that mistake again.
MarkB_MI
07-27-2005 03:13:52
My wife bought a 7500 BTU/hr portable unit last month and we put in in our bedroom. We don't have central air, it would be almost impossible to retrofit our house because there's no ductwork (hydronic heat). It happens that there's no window in our bedroom, just a patio door, so I would have to cut a hole in the wall for a window unit.
The portable units have a large hose, maybe 5" in diameter that has to be run outside. They suck air from inside the house and exhaust hot air outside, so I don't imagine they're as efficient as a window unit. They also have a tank to capture condensate; we have to empty it two or three times a day.
Ours works reasonably well. I ran the hose out through the patio door. By the way, does anyone know why Michiganders insist on calling a patio door a "doorwall"? I've lived here for over ten years and it still bugs me.
Gus
07-27-2005 03:54:44
 Re: Windowless Air Conditioner ? in reply to MarkB_MI, 07-27-2005 03:13:52
Dad and I used to be in the window business. In Mich. coincidently. Many years ago, before I was involved, the Andersen Window Co. (I think) used to have a setup where you bought the windows already in stud walls. It was called the Andersen Windowall. I assume this was in the 50"s or early 60"s but not real sure. I remember Dad telling me about it.Maybe this is where the term doorwall came from. I still here it now and then myself. Gus
buickanddeere
07-26-2005 22:48:04
I see them retrofitted into buildings or rooms all the time. The compressor and condensor sits outside. The freon/power/control lines run inside through a small hole in the wall. The evaporator and air cirulation fan are mounted inside the building. The inside AC unit just draws warm most air in and cool dry air out of it's self. No duct work.
Big Jim
07-26-2005 21:39:12
An air conditioner works by pushing cooled air one direction and heated air in a different one. Somehow you have to get the hot air outside of the area you want to cool. Central air does it with pipes of Freon connecting an inside unit and an outside unit. Window models are 1/2 inside and 1/2 outside. To work, the one you saw advertised must have some kind of connection to the outside.
Kevin Bismark
07-26-2005 20:59:04
I think the one you are talking about is the portable one, it's a flexable hose, like on a clothes drier that goes to a thing in a window to get the heat and moisture out, or you can hook them up to a clothes drier vent my brother had one a couple years ago and was defective from the factory and he went with a window shaker unit..
