Tool Talk Discussion Forum
Need advise on stuck nuts...(exhaust)
Matt from CT
07-25-2005 10:02:04
Hi Guys:
In the process of replacing the pipe between the manifold and cat on my '92 Volvo.
So of course, I need to take the pipe off the manifold, and the nuts are on studs into the manifold.
So I need to "do this right" the first time...if I snap a stud, it's off to the garage with the car since changing the manifold / replacing a snapped stud is beyond my shade tree capability and/or "convience" (I'm not laying on my back on my gravel driveway with little clearance to do it!!!!)
Been hitting it with PB blaster. I'll be buying the metric impact sockets & extension (hopefully the used tool place in Worcester will have them before I go to Sears!) so I can attack it with my impact wrench.
But before I put the impact wrench to it, I want to heat the nuts first to minimize the risk of breaking a stud.
Is this something I really should rent a oxy-acetylene setup to heat up...or would a simpler torch like a MAPP be sufficient? I have a simple Bernzomatic propane torch now, but I'm a bit lery it has enough gusto.
Nuts are about 5/8" (used by english ones just to get a feel for the size to make sure I buy the right metric ones...figure I'll get a 16mm plus a 15 and 17 just to make sure I have the right one!
Anyway, I'd prefer to be safe then sorry...but I'm really tempted the MAPP would be simpler for me to handle than an Acetylene one (I have a *little* experience with Acetylene...but not much!)
Thanks for any advice...and I have a few days :) Using the truck for now, parts aren't in till tomorrow, and the used tool place isn't open to Wednesday afternoon so I have some time to plan!
gun guru
08-11-2009 13:31:00
 Re: Heating a shop in reply to Larry Hardesty, 08-11-2009 06:42:38
The best bang for the buck in install and fuel price is ---Firewood. Plain and simple. Wood is a fraction of propane and a large wood stove can be found on craigslist or scambay. or your local area.
Coldiron
07-26-2005 16:05:52
 Re: Need advise on stuck nuts...(exhaust) in reply to Matt from CT, 07-25-2005 10:02:04
Matt, If you want to get a little stud insurance before you go to twisting on those rusty corroded nuts I would heat the studs with propane, or just run the engine to a good heat. Then put beeswax on the nuts, top and bottom and around the stud tops. Let her cool to ambient temp then give her a twist. The beeswax will work down and loosen what penetrating oils can not touch. I fired and worked on boilers for years and learned this trick after fighting stuck heated nuts and studs for over 30 years, the last 12 were made more plesant by this trick. And yes, I would use brass nuts on manifolds and muffler connections.
buss
07-27-2005 05:09:51
 Re: Need advise on stuck nuts...(exhaust) in reply to Coldiron, 07-26-2005 16:05:52
yes that beeswax will work wonders I also worked in a power plant. when I hear5d it in a class I thought he was nuts but it saved my butt many times.
2M
07-26-2005 10:33:47
Matt,
I will assume this is a 240 series, otherwise most of my comments do not apply.
The size of the hex should be 15mm, the thread size is 10x1.5mm just in case you will need it. You are correct you will not be able to get a nut splitter in this area, it will also be very difficult to chisel or cut (Dremel tool, etc) off the nuts without damaging the studs. The nuts are special and have a locking flange that will bite into the flange on the head pipe. If they need replacment get new ones from the dealer. Standard nuts have a habbit of loosening over time and you will be replacing the gasket again.
I have done a number of these and have managed to do almost all using a 1/2" impact wrench. Make sure you get the socket firmly seated on the rear nut, this one can be difficult to reach with just a straight extension. Hit the studs with a wire brush to get off the scale, then use PB and let sit for a while. As long as you can get a good bite on the nuts, you should be able to get them loose. The studs are pretty tough and rarely twist off.
Good luck...
Matt from CT
07-26-2005 11:28:40
 Thanks 2M...a 240 is exactly it! in reply to 2M, 07-26-2005 10:33:47
Yep, a 240 is what I have!
Matt from CT
07-26-2005 05:50:29
 What's the deal with the brass nuts? in reply to Matt from CT, 07-25-2005 10:02:04
Am I correct in assuming the idea is the brass nuts won't rust tight so next time the job is done, they'll come off? (Same idea as putting on the anti-sieze?)
Or is it they're more forgiving of any damage to the studs (even after running the die over them).
Car has 132,000 miles...knock on wood I won't have to do this job another time :) A friend of mine bought it for his college-aged niece who went, "Yeeeewwww...a Volvo?" and turned it down...so it sat in his yard for 7 months. Previous owners only put 3,000/year on it for the last several (lived & worked in the same city). I'm putting 100 miles each workday on it so the exhaust should be much happier now :)
Sure is nice having two vehicles finally -- using my pickup while the Volvo is up on blocks waiting for me to finish the job!
BBx
07-26-2005 04:41:39
I just replaced the muffler on my JD 950. The nuts holding it to the manifold were rusted to the point of being almost round. As someone else mentioned, I used my Dremel with a cutting disc and split the nuts. Pretty easy to do. Bought new studs and replaced those while I was at it since the threads were also badly rusted. I heated the first stud with MAPP, used some vise grips, and rocked it back and forth until it started to turn, then unscrewed it. The other 3 I tried without heat and they came out just as easy.
NC Wayne
07-25-2005 20:05:06
Hey Matt, you don't necessarily need a nut splitter, all you need is a good sharp cold chisel. Get one that has a thin cross section and make sure it's sharp. If the chisel is sharp it usually doesn't take but one or two good solid hits and the nut is spread enough to come right off. I've been taking turbos and manifolds off for years by splitting the nuts this way and I've never had any problems. Like the other posts say make sure you chase the threads before you put the manifold back on and if possible use brass nuts. If you can't do that at least use a good grade of high temp antiseize. Good luck.
buckva
07-26-2005 08:37:22
 Re: Need advise on stuck nuts...(exhaust) in reply to NC Wayne, 07-25-2005 20:05:06
Yep. that is the way to get er done.
Ken Crisman
07-25-2005 18:49:18
I remember as a boy when my Dad saw two dogs stuck together he'd use a brick to split those nuts apart . Good luck .
John Garner
07-25-2005 17:07:19
 A few thoughts . . . in reply to Matt from CT, 07-25-2005 10:02:04
Matt --
One of your biggest enemies is the paint, dirt, and corrosion that's on the exposed portion of those studs. A "rethreading die" of the appropriate size, which you can get from just about any auto supply store, used to clean those exposed threads will make a world of difference.
But even a rethreading die won't clean out all the crud that's right at the juncture of the stud and outer flat of the nut. A stainless "toothbrush" type wire brush (or the itty-bitty wire wheel on a Dremel) will get most of that.
Then, while you've got the wire brush out, clean out the area where the nut meets the washer and the washer rests on the exhaust pipe retaining ring.
Once that's done, fire up the engine and go have a cup of coffee.
When you finish the coffee, shut off the engine and soak the washers, nuts, and exposed portions of the studs with PBlaster. Wait five minutes, and spray them again. A few gentle taps on the ends of the studs would be a good idea; you don't want to hit them hard enough to break anything or deform the studs . . . just tap, tap, tap. Another five minutes of waiting and another soaking with PBlaster and you put your tools away and allow the engine to cool.
Come wrench time, use whatever socket or box-end wrench fits the nuts the most snugly. Don't worry about "metric or Imperial??"; just use what fits best. (Arithmetic says that 5/8 inch is 0.0049 inch smaller than 16 millimeter, but with manufacturing allowances and tolerances it's possible for a 16 millimeter wrench opening to be smaller than a 5/8 inch wrench opening.)
Six-point wrench openings are preferred if nut-to-wrench fits are equal, but I'd rather use a tight 12-point than a sloppy 6-point.
A few gentle hammer-taps may allow a socket that's just a skosh too small to fit by hand to seat on the nut.
Spray more PBlaster.
Be sure that the wrench is FULLY seated on the nut, NOT half-way engaged or angled.
Use gentle force on the wrench to "wiggle" the nut tight-then-loose, tight-then-loose, tight-then-loose for a few moments before concentrating on the loose. It's ok if the fastener moans and groans a little, but loud squeaking is a request for more oil.
If the stud wants to unscrew from the manifold instead of the nut unscrewing from the stud . . . let it. A new stud is easy to install.
Then, for your new installation, use brass (even better, if you can find them, bronze) nuts and a high-temperature anti-seize compound.
John
WBinPA
07-25-2005 16:20:29
Carol Martin has the answer. I have used this method several times. Wear safety glasses and it is much safer than a torch. Once nuts are split, you may need a larger socket to turn them.
Earl-IL
07-25-2005 12:17:27
You will need lots of patience.... Best is to heat the nuts with a torch until red. Let cool(If you can), tighten just a little then lubricate and back off. If nuts are corroded (rust) to the stud you may heat several times. Last resort is split the nuts with a nut cracker(special tool). All of this is better that broken studs.Patience. Earl
Carol Martin
07-25-2005 10:43:54
I would forget the heat and impact tool.. play it safe and use a Dremel tool with cutting disc and split the nuts. either that or get a GOOD nut splitter. ( tool that fits around the nut with a built in chisel tightened with a wrench) They work if done right.. Then Replace nuts with Brass ones.. after running a die over the threads..
Carol
Earl-IL
07-25-2005 12:21:23
 Re: Need advise on stuck nuts...(exhaust) in reply to Carol Martin, 07-25-2005 10:43:54
Sorry Carol, I didnt refresh my page before I posted. Earl
Matt from CT
07-25-2005 11:15:04
 Interesting idea on the Dremel... in reply to Carol Martin, 07-25-2005 10:43:54
I've never used a Nut Splitter before...but from what they look like, I don't think I have the room to use one in this case.
I might however be able to get up in there with a flexible shaft Dremel tool...
Keep the ideas coming!
Foz
07-25-2005 10:21:39
 Try wearing Boxers in reply to Matt from CT, 07-25-2005 10:02:04
Sorry, just couldn't let this one go by. Foz
buickanddeere
07-25-2005 15:17:13
 Re: Try wearing Boxers in reply to Foz, 07-25-2005 10:21:39
Them boxer/cycling shorts with the long legs that go 1/3 of the way to the knees are great. Saves getting chaffed when working/walking for miles on hot days.
Dug
07-25-2005 18:40:50
 Re: Try wearing Boxers in reply to buickanddeere, 07-25-2005 15:17:13
A dash of baby powder in them shorts really makes a difference, smells good too!
Dug
RustyFarmall
07-25-2005 10:16:53
You are correct about the propane torch, it will never create enough heat to do any good. Never used MAPP, so I don't know about that. Oxy/acetylene will definately get-er-done, but you have got to watch carefully with that or you will soon be heating something that shouldn't get that hot.
