Tool Talk Discussion Forum
TP Tools Blast Cabinet
Ramrod
07-25-2005 07:54:33
What do you guys thing of this cabinet for my garage? I want to move away from the sandblaster, for most of my stuff will fit in this cabinet, and save the sandblaster for the big jobs.
Ramrod
upred
07-25-2005 17:08:54
 Re: TP Tools Blast Cabinet in reply to Ramrod, 07-25-2005 07:54:33
I have a TP cabinet and its great, I would look at getting the foot pedal upgrade. just a thought
Rod (NH)
07-25-2005 09:21:44
Hi,
Yes, TP Tools makes excellent blast cabinets. I have a similar 960 model that I love. That's a great price for it too. Only one caution: If you are used to a pressure pot blaster, then you will be disappointed with the speed of the suction style that is standard in all cabinets, as far as I know. So that's not a downside to TP Tools models. If you are used to a suction type of blaster to begin with, you'll be pleased. One modification that I did to mine was to enable the use of my pot blaster inside the cabinet. The only change was to cut an opening in the access door in order to insert the larger hose and nozzle. It's not as flexible inside the cabinet but does work and it's about four times faster for the same amount of air. Here's what it looks like:
Click on the thumbnails for a full sized view
third party image
third party image
third party image Rod
e
07-25-2005 19:49:31
 Re: TP Tools Blast Cabinet in reply to Rod (NH), 07-25-2005 09:21:44
Got the same one tucked in the corner of my shop.....love it tons!
Charles (in GA)
07-25-2005 15:16:05
Looks like you got the finish line edition with the red paint and the larger window. Thats what I want, just need to go out back and dig up one of those coffee cans full of money..... ...
Guess I need to get off the stick and order one too, thats why I bought my 24 CFM 7.5 hp air compressor, was to run the cabinet.
Charles
Rod (NH)
07-25-2005 18:10:44
 Re: TP Tools Blast Cabinet in reply to Charles (in GA), 07-25-2005 15:16:05
Mine's the 960SE Patriot. At $1200 I can't see why it's worth 50% more than the $800 for the 960WL. The only differences that I can see is red vs white - no significant cost difference there. Mine has the larger window which is nice. It also has two interior lights instead of one. Thats nice also but can be easily retrofitted by the customer for a minor investment. Mine has the foot pedal valve as stock (with a non-trigger gun) rather than that being a $100 accessory. That's nice also. Mine included 25# each of three different blasting media instead of 50# of one kind - not much of a difference there. All in all, the extra niceties add up to a couple of hundred dollars worth in my opinion. $400 more for 'em is hard for me to see. I do think the extra $100 for the foot pedal operated gun assembly, while pricey, would be a good upgrade to get at the same time. That still leaves a $300 difference for the other "nice" differences. You can get the larger window for about $80 separately and if you are handy in such things, could retrofit that rather easily at some later time if desired. The units come very well packaged in a heavy cardboard-covered wooden framework all securely attached to a wooden pallet. It takes a while with a wrecking bar to get the thing out in the open such that you can unbolt it from the pallet.
RustyFarmall
07-25-2005 09:09:12
Looks like a pretty good deal to me. While you're at it, buy two of them, and send the second one to me.
Bob in ga
07-27-2005 13:34:35
 Re: TP Tools Blast Cabinet in reply to RustyFarmall, 07-25-2005 09:09:12
These look very nice, but I have a question. I have a whole shop vacuum system. What is the vacuum used for with the sandblaster? Is it only to keep the dust level down in the cabinet, or is it part of the reprocessing of the sand?
Couldn't I just use my own vacuum instead of buying another one?
Bob
Glen in TX
07-27-2005 17:38:48
 Re: TP Tools Blast Cabinet in reply to Bob in ga, 07-27-2005 13:34:35
Yes Bob, The vaccuum just keeps the dust down inside so you can see. Rust flying off and glass bead dust makes it dusty inside. I got a big 36"x48" cabinet I bought military surplus and just have one of the cheap 5 gal. shop vaccuums on it. I change the filters on vaccuum and run it till the motor goes out and buy another one. Built my own suction tube and bought a smaller Trinco blast gun to use with the foot pedal valve. They have build your own cabinet kits & parts too. www.tptools.com www.blast-it-all.com
