Tool Talk Discussion Forum
Tom's #5: Grease in the PTO Housing?
Soldier Tom
07-24-2005 17:41:30
Went and picked up the #5 today. Definately a well used piece of equipment. Well, took it to the carwash and $5 bucks later, I could see much green paint and other stuff under where the gunk used to be. I opened the hole to check the condition of the oil in the PTO Chain Housing (Z1038H), and to my surprise, it was packed with grease. No; not black, gooped up, cruddy, gritty old oil, but honest to goodness grease. And pretty good grease at that... Anybody care to venture a guess on the purpose of this? In my limited knowledge of this mower, I have ONE IDEA why this is full of grease instead of oil. Perhaps the seals got to leaking, and grease was used instead new seal? This mower is months away from the field, so I will take my time and make it right as I go. So how about it? Grease in the PTO housing.
Ludwig
07-27-2005 09:50:31
 Re: Tom's #5: Grease in the PTO Housing? in reply to Soldier Tom, 07-24-2005 17:41:30
Yup my old Hesston is like that. I pump 'er about 2/3 full of grease and fill the rest with gear oil. The gear oil is just there to prevent cavitation until the grease gets warm.
Fred Martin
07-27-2005 07:22:31
I have a bush hog brand 6" mower that the seal was leaking and I tore into it the right way...but the stump jumper wouldn"t come off...tapered spline...used lots of heat and big pullers (Torched two holes in it for puller) and wouldn"t come off! Had a spare stump jumper so decided to cut the old one off with torch. Worked okay but part of it fell on my foot. Hobbled around on one foot and uttered a few curse words. It had two seals in it and I replaced them both...noticed they went in too easy. Put it back together and it still leaked some. If it wasn"t such a job, I would have opened it back up and put some epoxy or loctite around the OD of the seals to take care of that. Pulled it outside and left it...never used it...too heavy for tha Massey 35. Fred OH
Van in AR
07-24-2005 17:48:01
I bought a tractor and was given a bushhog brand hog as part of the deal it was also packed with grease and has a bearing noise too. I put a little 90 weight in and it ran out the bottom, o joy now I can pull the stump jumper and change bearings and seals. gears are OK, just some lazy maintenance by someone. Looks like you got some of the same.
Van
