Tool Talk Discussion Forum
refill dry chemical extingishers
bjr
07-21-2005 07:24:52
All the cylinder testing/date stuff aside. Is it possible to get the require chemicals to refill dry chemical fire extinguishers? I would like to refill a some larger units for personal home use.
Red Dave
07-21-2005 09:34:36
 Re: refill dry chemical extingishers in reply to bjr, 07-21-2005 07:24:52
It can be done. Ansul has a line of extinguishers that users refill in the field using bulk extinguishing agent and small nitrogen charges that are then traded in to a dealer for new ones. They come in 5, 10, 20 & 30 lb sizes. Lets you select the agent for you particular hazard too: ie. sodium bicarb or purple K & others.
Standard stored-pressure extinguishers can be refilled too, if you know what you are doing. Ext. agent can bought in bulk, but you would need a source of dry air or nitrogen for the pressure charge. Moist air will cause the agent to cake.
I doubt that you can do it any cheaper than an extinguisher servicing company can do it for you though.
Stan in Oly, WA
07-21-2005 08:09:51
Hi, bjr
After I got out of the army in 1970 I got a job for a fire protection equipment company in Honolulu. We refilled dry chemical extinguishers all the time.
The commercial chemical in small extinguishers was baking soda with an anti-caking agent. Annual service of an ABC rated unit was to turn it upside down and hit the bottom with a rubber mallet, then shake it to make sure you could feel the chem. move. Then you flick the gauge with you fingertip to see the needle quiver to make sure it isn't stuck.
All the best, Stan
mike brown
07-21-2005 13:58:20
 Re: refill dry chemical extingishers in reply to Stan in Oly, WA, 07-21-2005 08:09:51
Check with your local fire dept. I don't think the testing requirements apply to home extingushers. The enviromental health and safety guys where I work will refill personal extinguishers. They say it's worth it to maybe save an employees home and lives.
