Tool Talk Discussion Forum
Friend Let The Smoke Out...Help!
Scott in Sandpo
07-20-2005 12:09:01
Howdy all,
I let a �friend� use my trailer and he set the Bulldog jack on the 7 pin RV electrical connector (male end) and crushed it. He then went to the store and purchases a new male end and wired it up without telling me.
I hooked it up to my truck to take it home, and while checking the lights somehow let all the smoke out of the wiring harness from the male connector to the wiring under the tongue. Blue lead �seems� to be the only one a little melted. I bypassed the �brake away� switch from the blue lead to help diagnose the problem. He assured me he had the wires correctly connected, but now the elec brakes don�t work.
Near as I can tell, he hooked the blue brake power lead to the ground and both ground (brake and light) wires to the power. I got the lights to work, but my Tekonsha Prodigy isn�t showing the brakes being connected to the trailer. Trailer (NEW last month) is fully loaded and sitting in a field quite a ways from the shop. One (?!?) wheel is locked.
What is my best way to track the wiring? Pulling the tires off will be a REAL pain where the trailer is located.
Ideas? Theories? ALL help is appreciated!
Scott
Coldiron
07-20-2005 21:34:09
 Re: Friend Let The Smoke Out...Help! in reply to Scott in Sandpoint , 07-20-2005 12:09:01
Scott, If that Sandpoint is in Idaho, I am busy till Sunday but can meet you and give you a hand with trying to reset the smoke back in that wiring where it is supposed to stay. Sorry but Sunday is the soonest I could help. Let me know, the email address is firfarmer41 at aol dot com if you need a second pair of hands and a couple of piles of paper showing hook ups. I just live about 1/2 hr SW of Sandpoint Id.
Scott In Sandpoint
07-21-2005 12:38:04
 Re: Friend Let The Smoke Out...Help! in reply to Coldiron, 07-20-2005 21:34:09
third party image
Coldiron,
Yep, good ol' North Idaho!
I'd bet you are down around Spirit or Athol? I hope they catch the guy who took his 12 year old daughter "camping" and hang him by his nads.
I appreciate the offer, but the trailer is 15 miles east of Bonners in a field past Moyie. I'm almost to the point of telling my "friend" to get his crap unloaded, get the trailer fixed correctly and deliver it to me in Sagle, but that wouldn't quite be neighborly. He's already sweating it pretty good, but I'll take whatever info I can get from this board and work on getting it out of there.
Scott in ugly, disgusting, flat worthless North Idaho
Coldiron
07-21-2005 17:45:08
 Re: Friend Let The Smoke Out...Help! in reply to Scott In Sandpoint, 07-21-2005 12:38:04
Scott, That is the second reg. S_ _ offender to hit N. Idaho real bad in 2 months. A nad hanging isn`t tough enough on those guys. We are in the HooDoo Valley west of Vay just off Kendall Rd. I like your description of the area. Keep the secret! If you need a hand just let me know and I`ll come a running. Got the last of my hay in the barn today.
Hermit
07-20-2005 18:03:58
Those plugs can be set up for RV trailers or horse trailers. It sounds like the plug was wired for the wrong type of trailer. There are several websites that will show the difference between the two connectors and how to wire them up.
Scott In Sandpoint
07-21-2005 11:57:15
 Re: Friend Let The Smoke Out...Help! in reply to Hermit, 07-20-2005 18:03:58
Hermit,
I called the trailer mfg (H&H) and found out they don't use the standardized wiring diagram for their trailers.
After the plug got crushed, my pal didn't look at the old hookup just hooked the harness wiring into the corresponding color lugs (W=W, BL=BL etc). This is what caused the melt down.
You'd think an 8 grand trailer would use the standard wiring wouldn't you? (grin).
Scott
T_Bone
07-20-2005 16:38:29
Hi Scott,
If the brakes are set without the plug connected to the tow vechile, then the breakaway cable has been set (pulled) applying voltage to the brakes as if the trailer became disconnected under tow.
Reset the breakaway then double check the wiring on the male end. On most covers have a wiring schemitic on the dust cover showing the correct wiring. It's easy on the male end to wire it upside down if one was not watching the locater pin.
T_Bone
Scott In Sandpoint
07-21-2005 12:12:24
 Re: Friend Let The Smoke Out...Help! in reply to T_Bone, 07-20-2005 16:38:29
T Bone,
I bypassed the breakaway switch while trying to figure out where my buddy went wrong with the wiring, but it didn't help.
as I mentioned to Hermit, he had wired the male plug almost exactly opposite from the original wiring. Maybe if I had rotated the plug 180 from the pin I wouldn't have this problem!
Scott
fepo
07-20-2005 12:32:14
if one wheel is still locked(when your 7 pin connector is not plugged in to your truck), either it's mechanicaly jammed up and you'll have to remove the wheel, or you must have a battery on the trailer for the brakeaway safety, you will have to disconnect the battery terminals and that should release your wheel... I think... not sure though.
then tow it somewhere to be worked on, open up the wire harness and look for fused/melted wires as far back as possible, replace/splice wires. Do a search in Google for '7 pin trailer connector' you will have the correct pin diagrams.
good luck.
Scott In Sandpoint
07-21-2005 12:21:25
 Re: Friend Let The Smoke Out...Help! in reply to fepo, 07-20-2005 12:32:14
Fepo,
The trailer does have a battery for the breakaway, bt I disconnected it while tracing fried wires.
The wheel is locked up with no power whatsoever. Is it possible that the brake welded itself in the closed position?
I'm going to try to remove the locked wheel and tow it to an easier place to work on it.
The easiest thing would be to roll the trailer over and check all the wiring, but he's got an old non-running 2N Ford with implements loaded on it and it would be a bear to unload it. I'm just not comfortable dragging the loaded trailer 50 miles or so with one wheel!
Scott
Vern-MI
07-20-2005 13:23:43
Try this for your wiring needs:
Scott In Sandpoint
07-21-2005 12:24:49
 Re: Friend Let The Smoke Out...Help! in reply to Vern-MI, 07-20-2005 13:23:43
Vern,
Thanks for the link!
I printed out the page to take with me and saved the link to my tractor favorites file.
If I have to rewire the whole trailer, you can bet I'll hook it up by color correctly so I don't have problems later!
Scott
