Tool Talk Discussion Forum
wierd eight sided hub bolt
Dale (MI)
07-18-2005 05:39:53
I finally got an air wrench so I can fix my car brakes and now I got these unusual bolts that I can not get out. They are rusty but appear to eight sided and slightly concave on each side. The heads are about 7/16. I cut some out but am concerned about frying the wheel bearings. They are too hard to drill for an extractor. Any suggestions on what they might be and what I need to turn them would be appreciated.
Charles (in GA)
07-18-2005 06:33:41
 Re: wierd eight sided hub bolt in reply to Dale (MI), 07-18-2005 05:39:53
Sounds like they might be Torx head bolts. They make sockets for them. Go to an auto parts place and look on the special tools boards for a set of black sockets with those funny looking broaching in them.
Torx is rounded in the bottom of the flutes as you describe.
Charles
Dale (MI)
07-18-2005 09:22:12
 Re: wierd eight sided hub bolt in reply to Charles (in GA), 07-18-2005 06:33:41
Thanks, I'll give that a try. I did find a
picture of a torx bolt and sockets online:
Link
Mine seem to be partially stripped, almost round.
Big Jim
07-19-2005 00:00:30
 Re: wierd eight sided hub bolt in reply to Dale (MI), 07-18-2005 09:22:12
If you have the room, take a standard hex nut that will almost fit over the head of your strange bolt. Drive it on and weld it to the bolt. It will let you get a good grip and, if you do it while the bolt is still warm,it will be a touch longer and easier to break free. I had to do that to several bolts holding the hubs on in the Suburban recently
Dale (MI)
07-19-2005 04:16:41
 Re: wierd eight sided hub bolt in reply to Big Jim, 07-19-2005 00:00:30
Got them out now. I bought a set of Craftsman bolt-outs and they worked great with the impact wrench. They fit over the bolt head and grip it with spiraled ridges. Thanks for the tip.
