Tool Talk Discussion Forum
where to get pulleys?? for my briggs engine
Jay87T
07-15-2005 17:34:01
hey guys Im restoring a old walk behind mower sorta of a no name brand or a old john deere, has a briggs 11 hp engine with a 1" shaft on the bottom, Im looking for pulleys for this thing with a 1 inch bore? anyone seen places on the net that sell em?
Jay
BobMo
07-16-2005 05:29:35
 Re: where to get pulleys?? for my briggs engine in reply to Jay87T, 07-15-2005 17:34:01
I buy them at my local industrial supplier. The local farm supply also carrys a smaller selection.
Not much help, but
07-16-2005 00:38:10
try Grainger, Motion Industries, a good old time hardware store, or industrial supply. What's the pulley diameter? You might be able to figure it out knowing the blade tip speed runs about 19,000 ft/min. Is the shaft keyed and if so, what's the keyway size? If the driven pulley is there, that's the belt width. You can use that pulley to get the drive pulley size. Example: a direct drive 20" blade X 3.1416 = 62.832" or 5.236'/revolution. 19,000 divided by 5.236' = 3628 rpm.
Gas engine direct drive lawnmowers run at 3600 rpm. Close enough.
Bob
07-15-2005 21:52:21
Punch the link below, and put "pulley" in the search box.
For new, McMaster-Carr should have about anything you need, IF you can qualify to buy from them.
Link
