Tool Talk Discussion Forum
hydraulic pump ID ,need help
oliver dave
07-15-2005 09:38:14
I have a vickers vain pump that I need to know how many GPM it is.The only #s I can find stamped on it are these.2520V 120 icc 10 then under it it has 38 .It,s a large pump with 3/4"double output, could 38 be the gpm?
George G.
07-15-2005 10:54:28
 Re: hydraulic pump ID ,need help in reply to oliver dave, 07-15-2005 09:38:14
The pump number should look something like this 2520 V 12 A 11 - 1 CC 20 . Some of the numbers/letters might not be the same. But in this example, the shaft end will put out 12gpm at 1200 rpm, and the cover end will put out 11 gpm at 1200 rpm.
oliverdave
07-15-2005 16:47:32
 Re: hydraulic pump ID ,need help in reply to George G., 07-15-2005 10:54:28
Thanks George, i'll check it again I may have not seen the other numbers.
