Tool Talk Discussion Forum
Who makes valve with R cast in body?
TomWNC
07-14-2005 23:34:55
I am trying to find a replacement steam control valve for a dayton steam cleaner. The valve has a R cast in the body. Does anyone know who the company is that makes this thing? It is a 1/2" fpt body with a needle type flow adjustment. It acts as a bypass for pressure / steam operation. And yes I did call Grainger parts but they want $65.00 for one. If I can figure out the manufacturer surely I can get it cheaper than that.
Thanks
T_Bone
07-15-2005 10:43:05
 Re: Who makes valve with R cast in body? in reply to TomWNC, 07-14-2005 23:34:55
Hi Tom,
Back a few years I ran into a valve with a "R" and it was a Robertshaw valve but that valve was 30 plus years old at that time, so about 50yrs old. I have no idea if that was a trademark or not.
Between Robertshaw and Honeywell they pretty well cover 90% of the low pressure (less than 15psi) steam market.
T_Bone
TomWNC
07-15-2005 12:03:49
 Re: Who makes valve with R cast in body? in reply to T_Bone, 07-15-2005 10:43:05
Hi T-Bone,
The valve is a bypass. The parts list refers to it as a metering valve. One side is connected to the water supply line that goes to the inlet side of the pump via a 1/4" hose barb which has a small orifice inserted into it. The other side runs to the high pressure line coming out of the pump via a 1/2" high pressure line. Per the instruction manual this valve is open for steam cleaning and closed for pressure cleaning. The cleaner is rated at 500psi. Could I just replace this with a ball valve?
Thanks,
Tom
