Tool Talk Discussion Forum
Need this tool
Greasey Hand
07-13-2005 18:02:02
It's to tighten the head bolts on a 806 856 IH
tractor. Its 13/16 & gets under & around the valve rack. A box end & 1/2" drive Its kind of u shape, any one got one for sale or know where I could find one. Thanks.
Joe (Wa)
07-13-2005 22:59:05
 Re: Need this tool in reply to Greasey Hand, 07-13-2005 18:02:02
You may want to check with a diesel repair shop for a p/n or source from one of their mechanics. We used to use these a lot on the older diesels that required retorque after initial run in. They were generally referred to in the trade as "under rocker arm extensions".
I bought a 11/16" boxend that was Snap-on (for Case tractors) about 4 years ago but they have discontinued them on their website.
If you are going to make your own as Bob described, you will need to have no off-set between center of the square drive and the center of the box end otherwise there will be lateral leverage that will squirrel the torque. That is pretty hard and time consuming.
Here is a link to what I consider a better way in a Case board post from george md.
I just hate people like George, yup Bob I've been hating you for awhile too :^)
Joe
Link: torque ext
Van in AR
07-15-2005 20:47:36
 Re: Need this tool in reply to Joe (Wa), 07-13-2005 22:59:05
If you put the torque adapter at 90 degrees from the wrench the torque will be correct. Sticking straight out you need to calculate the differance,
Van
Joe (Wa)
07-15-2005 22:21:24
 Re: Need this tool in reply to Van in AR, 07-15-2005 20:47:36
shame on you.
Joe
Dangit....try again .....
07-13-2005 23:12:55
Here is the link....blue poke thing doesn't seem to like me tonight.
Link
Bob
07-13-2005 21:05:06
If you just need it for a single use, and don't want to spend big $$$, you can bend a quality used combination wrench purchased on the cheap from a pawn shop, after heating with a torch, and then weld a cracked or spare socket to the top of it to give you the square drive for your torque wrench.
HJP
07-13-2005 19:08:22
try snap-on or mac they make alot of specialty tools such as the one I think your describing.
