Tool Talk Discussion Forum
14hp Briggs
Wrench52
07-12-2005 07:54:16
I have a 14hp Briggs Vanguard engine on a mower and the exhaust valve guide on one cylinder works its way out. This causes the valve spring retainer to contact the guide and bend or break the push rod. I had this problem last year and I taped the guide back into position and staked around it with a punch. This worked until now, its did it again. Any ideas? Other than to replace the head? I also put LocTite sleeve retainer on the guide. But I think the clearence is too snug to do any good and also gets too hot for it to help.
ScottP
07-13-2005 11:40:31
 Re: 14hp Briggs in reply to Wrench52, 07-12-2005 07:54:16
See if you can get a new guide. If not replace the briggs with a honda.
