Tool Talk Discussion Forum
The oil that creeps an loosens frozen parts!
Truetramp
07-11-2005 23:38:54
Since you guys did your best on trying to help me extract them headbolts that were broke off below the deck of the block, i thought i would share some of my secerts with you. I have been using this penatrating oil for years an it works great, now the wife or the misses may not above of it cause it stinks to high heaven. But i've used it on muffler cramps exhaust bolts an stuff that you would never even begin to believe you get get it loose. It's called Kano or Kroil penatrating oil, its made by Kano Laboratories Inc. in Nassville Tenn. area code 37211, phone number 615-833-4101
JSinIL
07-16-2005 08:45:24
 Re: The oil that creeps an loosens frozen parts! in reply to Truetramp, 07-11-2005 23:38:54
Aero-kroil is sold in Fastenall stores.
HJP
07-13-2005 19:16:24
I havent found anything I do that will resist
PB Blaster.
Although an old timer taught be to use some old brake fluid in a pinch in a junk yard.
Bernoulli
07-13-2005 09:33:22
I've been using Monolex by LE (Lubrication Engineers) recently with good results. The local distributor says he thinks it works better than AeroKroil except for rust-frozen parts and acknowledges that he isn't likely to sell it in a shop that has AeroKroil on the shelf. I'm also using LE's Almasol Dry Film Lubricant for re-assembly of woodworking machinery - doesn't attract and hold sawdust.
Big Jim
07-13-2005 00:45:37
I seem to have better luck with Kroil than almost anything else I"ve tried. You won"t find it in most stores. They explicitly do not market to the general public but I think it is worth the hassle to order the stuff.
Jim Cent IL
07-12-2005 17:44:54
I have used Kanolabs.com for years. It works. Give the nuts a shot, or drop, a day ahead. You wont need a breaker bar...
MAC,IL
07-12-2005 14:34:58
I have used a lot of penetrating oil, different brands. I slightly dilute rislone with kero and seems to do a good job. However you dont have the aerosol effect. Got to use it in a squirt can.
Van in AR
07-12-2005 14:24:16
Kroil is fine, works no better than Knocker loose. My favorite was 5-56, no longer available, went to Pow"r lube, not the same stuff.
Van
Hobo,NC
07-13-2005 17:10:33
 Re: The oil that creeps an loosens frozen parts! in reply to Van in AR, 07-12-2005 14:24:16
5-56 wuz good jus haveta live with Power lube, I have used it all and will stay with CRC
landlord7012
07-12-2005 15:32:16
 Re: Knocker-up in reply to Van in AR, 07-12-2005 14:24:16
I used a squirt of knocker-up 8/89 on my ex. 3 kids later my wallet and my hair are plenty loose!
Van in AR
07-12-2005 19:59:47
 Re: Knocker-up in reply to landlord7012, 07-12-2005 15:32:16
Landlord,
You got that right, I used three squirts of nocker up starting in 84 and still pay support on two out of three. Wallet stays on "E", what hair ain't turnin grey is turnin loose. lol
Van
dr.sportster
07-12-2005 13:40:43
The other day I had a contest between Aerokroil[11 bucks] and Liquid Wrench [3.50] each one worked so nobody lost except for 11.00 bucks a can plus mail order Ill probably buy more Liquid Wrench.Both smells drove wife to complain.
Mattlt
07-13-2005 05:32:29
 Re: The oil that creeps an loosens frozen parts! in reply to dr.sportster, 07-12-2005 13:40:43
My Dad would always say "go get the skunk pi$$," meaning the Liquid Wrench.
RustyFarmall
07-12-2005 12:41:44
I have tried just about everything anyone ever recommended on this board, and I can honestly say that none of them worked any better than good'ol WD-40, and sometimes it doesn't work either. I will admit that I have never tried Kroil, simply because I cannot find it locally. Now, If you were to send me a free sample of Kroil, I would use it, and if it works as good as you say then I also would recommend it. Just for the record, PB Blaster does not work.
Slowpoke
07-13-2005 02:08:53
 Re: The oil that creeps an loosens frozen parts! in reply to RustyFarmall, 07-12-2005 12:41:44
PB Blaster works fine for me. I no longer like Liquid wrench as they have thickened it with some black stuff. Same for Chevron carb cleaner. I bought some a few years ago and it looks like it has water in it.
Caz(Ky)
07-12-2005 10:44:34
Oil of Wintergreen is one of the best and most economical. Get it through your pharmicist. Just be forewarned - keep your hands away from your eyes, mouth, and sensitive areas of your body if any is on your hands. We used it in the Submarine Service for years and it is an vital part of Kroil. John
Fred Martin
07-14-2005 02:18:23
 Re: The oil that creeps an loosens frozen parts! in reply to Caz(Ky), 07-12-2005 10:44:34
We used to use it to shine aluminum lockers on surface craft. It sure makes the place smell nice. Fred OH
Joe (Wa)
07-12-2005 21:57:49
So what boat were you on? I remember white leading the crap out of all fastners.
Joe
Caz(Ky)
07-13-2005 06:54:04
 Re: The oil that creeps an loosens frozen parts! in reply to Joe (Wa), 07-12-2005 21:57:49
Joe, I was on the R.E.Lee, The Snook, & the Kamehaha. We used to white lead most non-nuclear fittings until lead started being controlled as hazarduous. John
Rockyhawaii
07-13-2005 23:35:05
 Re: The oil that creeps an loosens frozen parts! in reply to Caz(Ky), 07-13-2005 06:54:04
Caz, I hung out with some crewmen off the R.E.LEE when it sailed out of Pearl Harbor back in the early seventies. That during your time?
Caz(Ky)
07-14-2005 09:36:48
 Re: The oil that creeps an loosens frozen parts! in reply to Rockyhawaii, 07-13-2005 23:35:05
I was on the Lee fromm 77 to 81 and on the Kam from 85 to 90 if memory serves correctly. So ya I'm a little younger than some of ya'll but I retired (from the Navy) in 93. John
Joe (Wa)
07-13-2005 09:48:13
I was on Kamehaha (non-nuke rider) for 82 days in 1966, Hyman G.'s punishment for turning down nuke school. Caiman (SS 323) for 4.5 yrs prior that. Guess you are a tad younger than me LOL.
Joe
Leland
07-12-2005 09:31:41
I thought companys were supposed to pay for ads on this site
Too Far Gone
07-12-2005 16:33:11
 Re: The oil that creeps an loosens frozen parts! in reply to Leland, 07-12-2005 09:31:41
Ahh,You werent doing much anyway,if you're reading this stuff.
BobMo
07-12-2005 12:17:07
Ahhhhh , and I thought this was legit.
txgrn
07-12-2005 05:33:35
Thanks, but it is already the oil of choice. Grin
Mark
lance smith
07-12-2005 23:06:40
 Re: The oil that creeps an loosens frozen parts! in reply to txgrn, 07-12-2005 05:33:35
kroil and wd and lw can"t hold a candle to mouse milk , don"t know where to get it or who makes it but i"m now out of it.
txgrn
07-13-2005 06:25:16
 Re: The oil that creeps an loosens frozen parts! in reply to lance smith, 07-12-2005 23:06:40
Must really be great as Kroil advertises it will seep into cracks 1 millionth of an inch wide.....that's pretty small.
Mark
Bill WI
07-13-2005 08:24:53
 Re: The oil that creeps an loosens frozen parts! in reply to txgrn, 07-13-2005 06:25:16
Makes me wonder how they measure that 1/100000 crack.lol Sounds like advertising.
txgrn
07-13-2005 13:30:55
 Re: The oil that creeps an loosens frozen parts! in reply to Bill WI , 07-13-2005 08:24:53
Nope. 300 of the Fortune 500 companies use it (according to them). I just retired from one of those companies and that's how I got on to it. The machinists recommended it and it works.
Mark
Nolan
07-13-2005 03:29:15
Link
