Tool Talk Discussion Forum
Kawasaki TD18 weedeater Kaaz gas/oil ratio?
JL Sargent
07-08-2005 09:33:09
I just got the above mentioned weedeater at a yard sale. Looks good. Whats the correct ratio on this machine? Compression feels good but previous owner says its broke. Thought Id give it a try. Any help appreciated.
Big Jim
07-09-2005 22:54:59
 Re: Kawasaki TD18 weedeater Kaaz gas/oil ratio? in reply to JL Sargent, 07-08-2005 09:33:09
Boy, you hit one of my hot buttons. Why can't the manfactures simply cast the correct mix ratio into the plastic tank or the cap. If you have a couple of tools that are different, it is a pain to remember which is which.
JT
07-08-2005 10:55:52
Probably to be safe, I would mix it at 4oz. per gallon of non alchohal fuel. Use a good 2 cycle oil, though, designed for an air cooled engine. Echo, Stihl, Redmax, Husquvarna, Shindiawa all make good oil.
JL Sargent
07-08-2005 11:44:21
 Re: Kawasaki TD18 weedeater Kaaz gas/oil ratio? in reply to JT, 07-08-2005 10:55:52
I found it. Its 25:1. Problem Ive found is that the ignition system will shock you but doenst seem to have enough power to generate spark? Ever seen this? If I ground screwdriver in sparkplug cap I feel a shock but with plug in cap I can never get a spark. What next?
XXXRogerXXX
07-08-2005 21:51:49
 Re: Kawasaki TD18 weedeater Kaaz gas/oil ratio? in reply to JL Sargent, 07-08-2005 11:44:21
Change the plug.
JL Sargent
07-09-2005 05:25:14
 Re: Kawasaki TD18 weedeater Kaaz gas/oil ratio? in reply to XXXRogerXXX, 07-08-2005 21:51:49
I tried another spark plug. Ingnition is not creating enough spark Im afraid. I wonder if that can be repaired.
JT
07-11-2005 06:57:05
 Re: Kawasaki TD18 weedeater Kaaz gas/oil ratio? in reply to JL Sargent, 07-09-2005 05:25:14
Depending on the age of this critter, you probably have points under the flywheel. A 25:1 fuel/oil mix tells me this thing could be quite old, most manufacturers have went to 50:1 on trimmers and a few still use 32:1 on saws. I would explore and see if there are wires going under the flywheel, if you do, file, gap and clean the points and see if that helps any.
Jim
