Tool Talk Discussion Forum
Brush/Weed mowing.
Bunch
07-08-2005 08:51:01
What are the differences between a rotary brush mower and a flail mower?
Power needed, capability, safety, maintenance, preferred brands.
I have some old pasture, very little brush, so seems either one would work, might come down to price/maintenance.
Mostly for a path, lots of hidden rocks.
Tried a search, but don"t find anything that seems to fit my question.
kidbob
07-10-2005 12:50:38
 Re: Brush/Weed mowing. in reply to Bunch, 07-08-2005 08:51:01
I agree with David's termanolgy. But not the rock problem with the flail mower if you get the blades that swing on a 'D' ring and not one piece. I have been using a flail for twenty years
and tried both blades, the 'D' ring is much better at slipping over rocks and trash. I have never seen it throw anything more than 10 feet, and that is rare. All cuttings are fine and left where they were cut, no clumping. My 5 foot is powred by a dedicated 18 HP engine and will cut 6 foot high weeds or 2 foot high grass.
David - OR
07-09-2005 07:15:30
The terminology is imprecise and somewhat regional. Around here, a "rotary mower" refers to a classic "Bush Hog". These look like a giant lawn mower and are roughly square in plan view. A center hub spins two hinged blades. The hinging action reduces the damage when you hit something immovable (a rock, big stump, or a dirt mound). A 4 foot deck takes about 15 horsepower to spin, a 5 foot deck about 20 horsepower, a 6 foot deck about 30 horsepower.
A "flail mower" generally refers to something rectangular in plan view. The long axis is oriented perpendicular to the direction of travel. A spinning shaft is arranged parallel to the long axis and carries a series of 6 or more cutter blades.
For cutting paths through rough pastures with lots of rocks, you definitely want a "Rotary cutter". These are simpler, cheaper, and more resistant to damage. Their biggest downside is the rough end they leave on the stubble, and the fact that they chop the cut grass into irregular clumps. For (say) monthly use on your own farm, the cheaper ones like the King Kutter are fine. They do use thinner steel than the Woods or Bush Hog models, and will get dented and beat up over time.
A flail mower does a neater job of cutting, but is not very happy about digesting rocks. I think it is out of the question for your application.
FarmerDave
07-08-2005 19:24:05
I think a rotary mower is like a lawn mower. I.E. it has a solid blade for cutting.
A flail mower, maybe bush hog was the first manufacturer, has a pin in the blade that the outside length of the blade pivots on. So when the blade stikes something, the blade has some give.
Seems as though people like Bush Hog and Woods for these kind of mowers. People in general don't seem to be too fond of inexpensive models from the farm store like King Kutter.
I think if there's rock involved a flail mower is called for.
Mowing in rocks is said to be dangerous. Dad claims he's seen the flail mower throw a rock the size of your head 40 yards.
Bunch
07-10-2005 07:33:12
 Re: Brush/Weed mowing. in reply to FarmerDave, 07-08-2005 19:24:05
Sorry I did not get back to this sooner....
Thanks for the help, as with many questions, there are many sides.
Due to price/maintenance, I will probably start with the swinging rotary blade cutter, and move up to a flail when I have the intended path done.
And still be able to use the rotary for general clipping.
The momentum and ability to throw things a great distance will have to be addressed by safe precautions, and smart bystanders if any.
The walk behind brush cutter I mentioned can really toss things, and thats 8hp/100 pound belt driven unit, not a shaft drive several hundred lbs 30hp.
Most of the rocks I speak of are buried boulders that will do damage to the blades but are too big and flush to the surface to get picked up.
