Tool Talk Discussion Forum
CUTTING 1/8 ALUMINUM
JIMLLL
07-05-2005 19:34:42
Friends told me a circurlar saw with a carbide blade would cut aluminum. I tried it and it works great. I used a strait edge to guide the saw. I wore eye protection as the process throws chips.
hawaiirocky
07-10-2005 11:40:21
 Re: CUTTING 1/8 ALUMINUM in reply to JIMLLL, 07-05-2005 19:34:42
I bought one of those two-bladed, counter-rotating Craftsman saws made for cutting aluminum and other metal. Frankly, I think I wasted $180 and would not recommend one.
Bus Driver
07-06-2005 15:27:47
A plasma cutter is wonderful.
don OH
07-06-2005 14:49:33
yes you can use a circular saw. i do most everday on sheet up to 1/2" and extrusions,
to shorten or remove legs for forming
riverbend
07-06-2005 06:30:44
A decent blade in a band saw does a good job, if you take your time.
MLP
07-06-2005 06:02:24
At work we cut 1" thick aluminum with the table saw blade reversed. I have all so seen metal roofing cut with the blade reversed on a circular saw. Reversing the blade keeps it from digging in to much and all so keeps it from ripping the thin stuff.
ct_ct
07-06-2005 15:37:44
 Re: CUTTING 1/8 ALUMINUM in reply to MLP, 07-06-2005 06:02:24
Freud makes a blade for cutting aluminum.
It works real well in the table saw or chop saw.
We have been using the same blade for years now regulary cutting 1" thick aluminum with it.
