Tool Talk Discussion Forum
Conduit expander/compactor
Mattlt
07-05-2005 05:40:16
Wife bought me a new (cheap) screen tent for Father's Day. Left it up during a storm, and 3 out of 4 poles snapped off.
got to thinking that I could use 1/2 EMT conduit for poles. I don't want to be carrying around 8' long poles, so I thought there'd be a way to either "bell" one end, or compress the other, so the short ends would fit inside each other. I can't seem to find any kind of tool that would do this.
I'm basically looking for an exhaust tubing expander, but for 1/2 or 3/4 inch conduit. Not having any luck finding anything. Is such a tool made? Maybe I've just given away a Million-Dollar Idea?
Nolan
07-06-2005 03:39:29
 Re: Conduit expander/compactor in reply to Mattlt, 07-05-2005 05:40:16
Walk over to the plumbing area with the conduit in hand. Various pieces of pipe will fit inside or outside the conduit snugly. You then use the insert piece, and pin it in place on one end. That's what I've been doing for years with 1/2" conduit when I build hoop houses and the like out of it.
Vern-MI
07-05-2005 08:37:55
What is the I.D. of the �" EMT? If you could find something that is the diameter of the conduit I.D. then fix it on one side with a screw and when using just slide the other end into the matting �� EMT. Probably could even be a piece of ash or hickory dowel wood. You could also use it to plug the open ends so they don�t fill with sand and clay.
Mattlt
07-05-2005 08:43:46
 Re: Conduit expander/compactor in reply to Vern-MI, 07-05-2005 08:37:55
That's probably what I'll end up doing. I just thought that there had to be a tool to do this. (I never like to pass up an opportunity to add another tool to the collection. :-) )
ScottP
07-05-2005 08:22:14
Matt
A hydraulic hydraulic hose fitting press is what you use for this. The press will make one end smaller so it will fit inside the other pole. Find a shop that makes hoses' and see if they will do it for you. Scott
MAC,IL
07-05-2005 06:27:21
I think you are looking for swaging tools, might try RIGID and see what they got. You will probably have more tied up in the tools than a new tent.
MAC,IL
07-05-2005 06:30:11
 Re: Conduit expander/compactor in reply to MAC,IL, 07-05-2005 06:27:21
You might try connecting them with conduit couplings that have the screws and not the comp. fittings.
Mattlt
07-05-2005 07:07:33
 Re: Conduit expander/compactor in reply to MAC,IL, 07-05-2005 06:30:11
Thanks for the ideas. Found a couple of swaging kits online for about $25, but it doesn't seem like they go very deep. Thought this tool would be handy for other projects as well. Maybe I'll have to invent something.
T_Bone
07-05-2005 07:18:31
 Re: Conduit expander/compactor in reply to Mattlt, 07-05-2005 07:07:33
Hi Matt,
Mac is correct is what your wanting is a swagging tool but they won't expand 1/2"emt for a snug fit as there made for swagging CU tubing sizes. Been there done that.
Also the steel hardness seams to make the swag pin offset to one side, not centered.
Use lots of oil on the swag tool with a flaring tool vise to hold the emt while expanding.
If you do find a snug fit swag tool for 1/2" or 3/4"emt, please let me know as I have a use for one.
T_Bone
Glen in TX
07-05-2005 12:43:02
 Re: Conduit expander/compactor in reply to T_Bone, 07-05-2005 07:18:31
Matt, I don't think it is that hard to make your own swaging tool out of a piece of shaft. I have a light bulb changer with extentions and it is just made of 1/2" conduit and I wanted to make more handles for my chimney cleaning brush out of 1/2" conduit. I cut a slot with a hacksaw down the conduit pipe about 4" and then had measured a piece of shaft that was about the same size as OD of the conduit and ground one end off bullet shaped and just drove it in with a hammer to expand the tubing while holding the conduit in a vise. Put some vegetable shortening or silicone on the shaft so it will drive in easily. Then to clamp it snug just use hose clamps. I've made several like this before and don't remember needing a special size shaft to make the tool. It's a lot lighter pole with a stout connection than useing pipe or shaft inside for connectors.
