Tool Talk Discussion Forum
cutting stainless steel
Foxtail
07-04-2005 14:45:18
Is there such a thing as a cheap easy way to cut stainless into small enough sizes to take to scrap yard. It's an old tank. Thanks.
Big Jim
07-08-2005 02:47:36
 Re: cutting stainless steel in reply to Foxtail, 07-04-2005 14:45:18
See if any of your friends have a plasma cutter you can use. They will make short work of any thin material that is conductive.
don OH
07-06-2005 18:08:38
foxtail, if your cutting up and old milk tank be careful of the refrigerant oil in the cooling lines. that stuff will flame up or even explode when heated.
Walt of CA
07-04-2005 20:33:45
To hack up stainless, use 6010 electrode and a welder big enough to power it. It'll blast right through; not pretty but it works. Kinda like what happens when you're learning to weld...
Bernie in MA
07-04-2005 17:12:38
If you have access to a goodsized welder and a compressor an arc/air torch should work.
ryan bland
07-04-2005 15:33:05
cheap cut-off wheels for a grinder, you can get them at your local hardware store, just don"t cut off into a old g as or diesel tank unless you fill it with water first
