Tool Talk Discussion Forum
OT......Watering Can Repair
WaterCAn
07-04-2005 08:02:45
Know this WAY off topic, but could use some advice. My wife purchased a vintage galvanized steel watering can at a yard sale. Due to its age a small part of the bottom seam is cracked and of course leaks. What's the easiest way to fix??? Melt lead???, weld??? Ideas are appreciated!!! THANKS!
T_Bone
07-06-2005 09:34:16
 Re: OT......Watering Can Repair in reply to WaterCAn, 07-04-2005 08:02:45
Hi WC,
When soldering galvanized, use cut muratic acid. Cut acid is made from pouring some muratic acid into a glass bowl then dropping in a few galvanized chips. Let the acid stop boiling then it's ready to use.
Muratic acid, also called battery acid or pool acid, is 40% Sulfuric acid. Lab grade sulfuric acid is 70% acid.
Most cans are made with a rolled hem seam. After awhile this seam will become loose and leak. Spread on a liberal amount of acid then use a 95/5 tin solder for domestic use.
Dot not use a open flame for a solder heat source. Heat a piece of copper then use the copper as the heat source. Using a open flame will add carbon to the galvanize causing the solder not to seal.
T_Bone
James in North Carolina
07-06-2005 12:06:38
 Re: OT......Watering Can Repair in reply to T_Bone, 07-06-2005 09:34:16
T bone, not sure if it makes any difference but muriatic acid is actually hydrochloric acid. In concentrated form it's still bad stuff, but not near as bad as concentrated sulfuric acid.
T_Bone
07-06-2005 12:55:56
 Re: OT......Watering Can Repair in reply to James in North Carolina, 07-06-2005 12:06:38
Hi James,
Thanks for the correction as hydrochloric acid would be correct. I need to proof read better.
T_Bone
TimV
07-04-2005 10:03:13
If functionality is your main concern, just use JB Weld--I've fixed several this way.
MAC,IL
07-04-2005 09:20:41
Fabricate a Patch and plain old solder.
msb
07-04-2005 08:23:15
Clean it real good and solder it with some lead acid solder.
Weirsdale George
07-04-2005 08:55:53
 Re: OT......Watering Can Repair in reply to msb, 07-04-2005 08:23:15
I would add one step -- fashion a patch out of brass shim stock to cover crack, tin, then solder.
