Tool Talk Discussion Forum
Stihl 031 won't run
vaclav
07-01-2005 17:24:54
I cannot get this old saw to run.
It will start with starting fluid. Has ( as far as I know ) clean gas. I blew air into both adjusting screws. They are set at 1 and 1/4.
What else can I do besides tearing down the carb itself?
The whole problem started that I had to run it with choke about 3/4 closed.
Vaclav
Ex Logger
07-08-2005 08:19:49
 Re: Stihl 031 won't run in reply to vaclav, 07-01-2005 17:24:54
It is usually one of two problems that can be fixed with a carb kit available for about $18. Remove the carb and remove both sides of the carb from the body. On one side there is a fine mesh fuel inlet screen that can get clogged. It just pushes into a recessed hole, you can pull it out with something small and sharp and then push the new one in...the eraser end of a pencil works good for this. On the other side of the carb is a diaphragm, if this is rotten or has a hole in it the needle valve won't open to let gas in from the tank. Good Luck
hay
07-02-2005 09:26:27
i was always told stihl made a very good chainsaw and weedeater, however after owing and using both mine infrequently, i am to the opinion they are no better than anything else on the market. i had both of mine in the repair shop several times and it seems like i use them 3 minutes and work on them for 30 minutes. i do know they are very finicky about fresh gas/oil mixture. if it is in the tank more than a few weeks, drain it and install fresh gas. also check the spark plug after every third or fourth time of use. they tend to foul up quickly. both of my stihl machines are hard to start and always have been, even from brand new. must be their trademark.
Stihl fan
07-03-2005 05:23:06
 Re: Stihl 031 won't run in reply to hay, 07-02-2005 09:26:27
I have had my 029 for 10 years, purchased it new, and cut about 12 cords of ash every year. I have never had even the slightest problem. Not only does it run like new, it looks that way. I have become a serious Stihl fan.
MAC,IL
07-01-2005 18:41:29
As stated, check fuel filter. Then look for bad gas lines, could be a collapsed one or cracked. Cap vent may be plugged. Those carbs are real simple. Kits are pretty cheap. May as well check the muffler screen also.
Hernit
07-01-2005 18:04:27
Have you checked for a dirty fuel filter?
