Tool Talk Discussion Forum
Lawn Tractor Fixxer-Upper
XXXRogerXXX
07-01-2005 13:34:55
third party image
Hi again folks. Just wondering if you could give me a bit of advice. I know this isn't a "real" tractor, but I think there are probably a few here who have an interest in smaller machines. I have been looking for a cheap garden tractor for mowing the rear yard where I live. It's probably over a half acre, closer to a full, and takes me about 1.5 hours to mow with a Craftsman push mower. Now maybe that's not a great deal of work to most, but it has been scorching hot here this summer, and the yard needs doing every week, or two at the most. This greatly cuts into my leisure time, and after working all week in a sweaty warehouse or over some smoking hot compressor, I like to kick back on the weekends. I can't justify spending a lot on a machine, since I am saving for my last year of school. however, if the price was right, I was certainly willing to take on a bit of a resotoration to working status of a rough around the edges machine. I have found one locally for $200 that is admittedly tired looking. It is a Massey Ferguson, which, although I know next to nothing about tractors, is a recognizable name to me, like John Deere. It also looks old enough to be a "real steel" kind of machine. I was just wondering if anybody could tell me if they thought it would be financially worthwhile to bring up to snuff for the mowing job at hand. Things like headlights aren't important to me, as it will only be used in the daytime. Naturally, anything catastrophic like a blown motor or rearend would disqualify it, but I am just curious what you all think about the machine. Disregard the no E test and safety note. I think it's a generic message he applies to all ads for old vehicles.
Harvey1
07-02-2005 04:29:35
 Re: Lawn Tractor Fixxer-Upper in reply to XXXRogerXXX, 07-01-2005 13:34:55
Roger You can't buy too much for $200., this machine looks a little 'rough' but the tires look good and the steel looks straight and somewhat rust free. If the deck is ok and the motor runs ok, you got a deal. You'll probably still end up putting a few bucks into it (belt, filter, battery, plug, etc).
youngster
07-01-2005 19:29:44
 A bit of experience in reply to XXXRogerXXX, 07-01-2005 13:34:55
Roger, You mentioned you wanted a garden tractor in your post as far as i can see by the pictures that isnt a garden tractor but rather a lawn tractor which is smaller in stature and mowing capacity. Whcih for an acre is ok so long as you dont have alot of hills. those little lawn tractors dont have enough weight to them to do good on hills,trust me ive used some in very inhospitible conditions and didnt have good results almost flipped a couple of them. that being said massey fergeson as a lawn tractor was not so popular as far as im away i may have seen one. Around these parts a used cub cadet lawn tractor is worht 200 so long as the decks there and the engine is good and so is the rearend. as for that fergeson it is very rough for two hundred well at least for any of my two hundred. Two years ago a neighbor of mine had a sears suburban garden tractor in vverrry verrry nice shape for 250 so i wouldnt be gone hook line and sinker on that what looks to be a clunker. go to some local garden tractor dealerships and see what kind of used tractors they have sometimes you can make out pretty good, maybe even get one that is a fixer upper for 50 buck and put 75 to it and have a workin machine. its been done around here. best of luck to you sam
RickL
07-01-2005 19:26:18
I have a JD LX176 that runs a nd mows fine ,is hydro stat drive. It leaks oil out the bottom seal. A new seal cost less than 20.00. I don't need it anymore and it is still a good usable machine with a little repair. $500.00 for it
Charles (in GA)
07-01-2005 19:18:29
Closely examine the deck on top in the low areas around the shafts and bearings, people tend to let grass clippings accumulate and they get wet and rust the deck out. Simple enough to take a blower and blow it out each mowing, most people won't bother. You can fix almost everything on the mower, but if the deck is gone, you probably cannot get a new one, and its not worth anything with a bad deck.
If it cranks and runs OK, mows OK and none of the parts such as steering seem too loose, its probably a better mower than some of the newer ones.
I tell people, if you can come across a zero turn mower, a commerical model, you are much better off. Second to that is a stand on the back type that a lot of lawn services use. Some lawn services are smart enough to sell them off before they get too far gone, one of those would last you a lifetime, much better than a comsumer mower.
Charles
John,PA
07-01-2005 13:40:36
YES SIR.... I really think your "mini" tractor will give YOU many years of good service.
Spindle bearings for the mower deck might be need'n looked at though. No problem finding replacements.
Hope this helps. John,PA
larry in tn
07-01-2005 14:23:28
 Re: Lawn Tractor Fixxer-Upper in reply to John,PA, 07-01-2005 13:40:36
Roger
You never know on some of these old mowers. If it starts and isn't blowing oil or knocking your off to a good start. I've put a few back to work and had good luck with them. Test drive it and try the deck out. Just check it out in general. Before I became an air compressor nut I was an old tractor and outboard motor nut. Actually made some $$$ on the old clunkers.
Lastly see if you can get a better price from the seller. It's part of the game.
