Tool Talk Discussion Forum
Thread problem
Jim- DR
06-30-2005 17:06:32
My Delta bandsaw has a 5/16 thumbscrew that locks down an adjustment dohickey. But it fits so loose that it woobles in the threaded hole and loosens very shortly. Is there something I can coat the threads with to increase the diameter, or is there a different solution? It is something the has to loosened frequently.
Charles (in GA)
07-01-2005 11:02:22
 Re: Thread problem in reply to Jim- DR, 06-30-2005 17:06:32
For long lasting durability, Gene's idea is the best. Go buy a single size heil-coil kit and it will have the proper size drill to open the hole up and the proper (special) tap to prepare the hole for the helicoil. Then run the coil in and break off the drive tab and you are done.
As also suggested, use a wingnut as a jam nut and put the rest of the heilcoils and kit in the toolbox for another project.
Charles
Bus Driver
07-01-2005 10:34:00
Clean out the hole that has the female threads with lacquer thinner. Then fill the hole with mixed epoxy. When cured, drill with proper tap drill size and retap to original size.
flathead
07-01-2005 08:54:19
I"ve got a delta bandsaw with a thumbscrew wheel adjustment that also has a wingnut on the thumbscrew. Once you get the blade tracking where you want it, you tighten up the wingnut to lock it in place; just like a locknut.
flathead
Pharmall
07-01-2005 07:01:27
Maybe wrap some aluminum foil around the threads? Just a thought for a quick fix. The other suggestions about re-drilling and tapping to a larger size are more permanent and would last longer.
MAC,IL
07-01-2005 06:18:59
Thinks I would opt for the next size larger. If the piece can be removed and is weldable, fill the hole and re tap it.
Gene Davis (Ga.)
06-30-2005 20:02:02
There is a thread repair system called "Heli-coil" that is a thread insert that will return it to the original thread size and if it is aluminum or some other soft metal, it will be a stainless steel thread insert that will be very strong for long term us. Gene Davis
Stan in Oly, WA
06-30-2005 17:18:12
Hi, Jim
You could get a 3/8 tap and increase the threaded hole to that size, then use a 3/8 thumbscrew.
I'll bet somebody has an easier solution, though.
That's what's great about this forum.
All the best, Stan
Fred Martin
07-07-2005 14:46:43
 Re: Thread problem in reply to Stan in Oly, WA, 06-30-2005 17:18:12
Stan...being that you mentioned it...maybe he can try my method. I once had a screw adjustment for a carburator that was stripped out...or wore out. Being that I needed the tractor yesterday...I needed a "quick fix". I wrapped a piece of string around the screw and screwed it back in and it lasted forever. You gotta get smarter than the metal. (grin) Fred OH
