Tool Talk Discussion Forum
Used Trucks
Phillip Al
06-26-2005 22:29:26
I would like to get your opinions on a 2002 Dodge 2WD 4 Door vs. 2002 GMC Z71 extended cab trucks. I can get a bargain on either one, but I dont know a lot about the 360 in the Dodge. What kind of mileage is realistic for both and is one of these a lot better than the other? I don't actually need the 4wd much, but have had one for years. We usually use it for our family (wife and 2 small girls) and to occasionally pull trailer for 3000 Ford tractor and boat. Thanks for any insight.
Leland
06-27-2005 20:29:49
 Re: Used Trucks in reply to Phillip Al, 06-26-2005 22:29:26
Any more the parts cost to much for either and they both spend about the same amount of time in the shop being put back together so flip a coin they are both about equal.
RickL
06-27-2005 10:24:40
I owned one chevy 77 3/4ton 4wd bought new. 6mile gals was best it would do. sagged when put seed in back terrible tranny out at 40,000. front case out before that. wouldn't have one if give to me. Had dodges eversince and still running them. Iuse them till they go to my buddy who runs car crusher. All had over 170,000 to 200some thousand. Last unit I had was a v10 3/4 to extend cab long box, simpley loved it worse it got was eight pulling heavy trailers in the field. on road trips it would do 13. it was 1996 with 145000 miles on it when i lost it in a fire. It was a nice truck pull anything ride very nice. Now have a 2004 dodge 3/4 ton club cab long box with the hemi. doesn't compare in power but it has been getting 15-16 miles gallon regularly,haven't pulled with it much yetstill have to put cushion hitch and fifth wheel hitch in unit. For me it has been dodges period and they always carried the load better for me. like I have said before if it works for your thats all that matters.
Tig Welder
06-27-2005 10:12:27
We run mopars,2 of them are one tons. One gas with a 4.10 rear end and auto trans.This one gets 15mpg empty and 9-11mpg with the bobcat and trailer.This one we replaced the lockup trans.at 110k with a older a-727.It turns some pretty good rpm's at 65mph,but I will run till the wheels fall off.The other one ton is a CTD,60k and NO PROBLEMS..... .it gets trans fluid and filters changed every 15k,and this one pulls a 3 horse slant most of the time.The last one is a 1500 5.2 auto 100,000 no trans. problems. Once again this gets regular trans. fluid and filter changes.This one is the daily driver,3.55 gear ratio gets 13-15mpg in town and empty on the highway got as much as 18mpg. A few years back we ran a couple of GM'S just had no luck with them.
MAC,IL
06-27-2005 05:59:55
Never had a dodge. No desire either. Chevy all the way.
Mike M
06-27-2005 05:29:11
I'd take a serious look at a Toyota. I have a 1996 Dodge ram 2500 360 gas 4x4 ext.cab I bought it with 85,000 mi. and it now has 160,000 on it.I'm just now having tranny troubles-sometimes it sticks in 2nd seems to work when pulling I'll run it til it quits.I get from 12-14 mpg which is a combined city and hwy.Worst ever was pulling a heavy trailer loaded both ways 7.5 mpg I'm sure if I just ran straight hwy. my figures would go up,but seems like if I go somewhere I'm pulling something.I have a 355 rear end ratio and that 360 will do better than any 350 chevy or 351 ford.Not as good as a 454 or 460 but I can get by and when empty my gas mileage goes up.I have owned some chevys and fords a couple of each,but this is my first Dodge and it is the best truck I've ever had.I would buy another Dodge but I don't need to as this one just keeps going.Figured I got a good one better keep it ! LOL
hawaiirocky
06-27-2005 00:53:42
That Dodge Transmission problem comes up whenever you talk trucks, for the past few years, so people are leery about buying them. I know many guys that have Dodges without the problems, but the stories are still out there. Until Dodge remedies this in a meaningful way, I'd go with the Chevy too,
Van in AR
06-27-2005 07:53:13
 Re: Used Trucks in reply to hawaiirocky, 06-27-2005 00:53:42
Rocky,
Your only 4 or 5 years behind the times. Dodge updated the Auto transmissions in 2000. They had problems with the 98 and 99"s with the V 10 and the Cummins because of the power and the way people were loading them. I have a 2001 with a Cummins with 117,000 on it and it hasn"t missed a beat. I service it every 15,000. Half of my trucks miles have been with a Gooseneck trailer on it pulling equipment.
Van
Galen
06-27-2005 09:33:43
 Re: Used Trucks in reply to Van in AR, 06-27-2005 07:53:13
Don't know - neighbor's was a 2005, BIL's and co-worker's were 2002, cousin had 2000, 2001, and 2003. All still had problems with the tranny, and all were told Dodge had it fixed! Glad to hear you're have good luck with yours!
Galen
06-27-2005 05:18:24
I've known SEVERAL guys who own(ed) Dodge trucks and had the tranny (and other pieces) die, some more than once! Tried to talk my BIL out of buying a Dodge, but never listened. In the year and a half he had the thing, he had over $10,000 in repairs ABOVE what warranty covered. Guy I worked with (occasionally) had one - in 120,000 he had replaced the tranny (twice), front end, rear end, transfer case(twice) and others. He had close to $25,000 in repairs (beyound warranty) - and he called ME LUCKY when I mentioned I had 300,000 on my Ford with ZERO troubles (O2 sensor(3),ABS senser, & radiator) Neighbor had a brand new Dodge this spring - for two weeks - until the tranny went south. He gave it back to the dealer and has a Chevy now. I could go on .....Never thought I'd be able to say this, but of those two, buy the Chevy. I'm sure there are those out there who have good fortunes with Dodge - I just ain't met one yet! 8^)
Mike M
06-27-2005 05:33:47
 Re: Used Trucks in reply to Galen, 06-27-2005 05:18:24
I attribute alot of Dodge tranny troubles to people checking the fluid like a Chevy of Ford in park. You do not do this on a Dodge mine says check in neutral. Big difference if checked in park you will be way low on fluid. Even some of the techs. at dealers don't do it right.
Galen
06-27-2005 05:51:45
 Re: Used Trucks in reply to Mike M, 06-27-2005 05:33:47
I don't know the cause, but know several people whith problems. Even my cousin (his Dad, my Uncle Glenn, was a STAUNCH Dodge man 'til the day he died) gave up on Dodge after having problems with THREE of them. Not everyone can be checking the fluids wrong! Didn't mean to start a war! You've obviously had good luck with yours!
Mike M
06-27-2005 10:12:42
 Re: Used Trucks in reply to Galen, 06-27-2005 05:51:45
So far,that's why I better keep it. Every other truck no matter what brand has been a lemon.Based on how good dads 1986 Toyota he bought used has held up and another one a guy at work has that the frame rusted in two and still can't kill both pieces ! LOL I'd be shopping for a Toyota only these days.
RustyFarmall
06-27-2005 11:52:04
 Re: Used Trucks in reply to Mike M, 06-27-2005 10:12:42
Don't mean to argue but Toyota does not build real trucks. They do build some nice compact pick-ups, but nothing to compare with a full sized 3/4 or one ton American made truck.
Mike M
06-28-2005 05:40:56
 Re: Used Trucks in reply to RustyFarmall, 06-27-2005 11:52:04
Yes they are lacking in a heavy duty truck,at least here in the USA. I don't know for a fact but I'd bet they have some they sell in other countries like Merceades does. Thier trucks they do sell for the most part are every bit American Made as Chevy and Dodge.Toyota has plants in the USA most Chevys are made in Canada. I think the Dodges are now made in Mexico mine says it was made in USA maybe that's why it is holding up better than all the rumors.The new industry phrase is North American Content this covers Canada and Mexico but most people on quick glance think it means USA.
Rod in Smiths Falls, ON,
06-27-2005 16:32:34
A friend who services my 95 4Runner is a GM Master Technician, the kind who regularly gets free tropical vacations courtesy of GM Canada.
When he took the original rotors and calipers off my Toyota at 285,000 km he saved them to show the GM guys who are having big trouble getting them to last past 50,000 km on the new trucks.
He says nothing he has worked on compares to this Toyota's parts quality, and this is a 4 cylinder, 5 speed 4X4.
When I find another truck as good, I'll buy it.
Mike M
06-28-2005 05:57:55
 Re: Used Trucks in reply to Rod in Smiths Falls, ON, , 06-27-2005 16:32:34
Yep I see alot of bad rotors on GM cars here at work,they have replaced thier fair share of trannys too! We get stacks of service bulletins and recalls every day,very sad.These GM's are either leaking oil or antifreeze.Dads old Toyota with 160,000 miles will not leave a drop on a concrete floor nor does my Dodge Ram and Voyager Van or my new old 1996 toyota rav4. I have to make my wifes friends driving thier Fords and GM's park over in the gravel so as to not make a mess of my concrete approach to the garage. These companies are all in cahoots these days. Case in point, the other day we were working on a Grand Cherokee heater controls tech needed an actuator and said it looked just like ours (Cadillac)I went and looked at it, copied down the part number and sure enough it came up in our system (GM)even had one on the shelf ! Pulled it out of the box and the number didn't match GM but looked more like a Chrysler number.
pperry
06-27-2005 00:34:10
no need to think about it. go with the chevy for sure. dodge is to well known for their automatic trany"s to burn up. the 4 door may sound apealing and more pratical for your needs, but overall you will probaly be much happier with the chevy.
