Hi Matt, Not much choice for a typical home shop for accurate holes, .010 or so, but here's what works for be. First buy a dial indicator, even a cheap one is better than none at all, and adjust your runout on your quill on the drill press. Mine was out .015 and with a brass hammer I knocked it back into .002. So far it has stayed in alignment for several holes, about 50. Use a piece of scrap piece of 1/4" metal under the 14ga to keep the the pilot bit running true. After you drill the pilot hole then adjust your bit so it rides on the smooth shank of the pilot bit while cutting the large hole. Clamp your work to the table securely. Once clamped and the pilot hole is cut, do not change the alignment until the final hole is cut for any reason, including adjusting for table hieght. Next flood the holesaw teeth with cutting oil as you cut. Used/new motor oil works for me. Adjust your cutting down pressure to remove all chatter. If you can find the correct size knock out punch that will work well. I only buy Greenlee plug cutter punchs. You can buy metal punch and dies for just about any hole diameter, costly tho and it would be cheaper having a machine shop cut them for you and more accurate. T_Bone
