Tool Talk Discussion Forum
need a 14.4 volt battery replacement for drill m
Ben Maisen
06-26-2005 11:50:37
I would like for anybody to give some leads to web sites to find replacement battery for a 14.4 Volt Drill Master Combo kit model 40056. I really Need this replacement battery bad. Sign, Ben Maisen
Hey Ben..John,PA
06-26-2005 21:04:23
 Re: need a 14.4 volt battery replacement for dri in reply to Ben Maisen, 06-26-2005 11:50:37
Recently, I received a new catalog from ALLIED ELECTRONICS. They list batteries fer 'bout everything.
I understand that "if the clerks want to.. RADIO SHACK can order the same items from ALLIED".
Hope this helps. John,PA
Slowpoke
06-26-2005 20:05:46
It sounds like a Harbor Freight battery. Go to their store or www.harborfreight.com. If not, put '14.4volt batteries' in the google seartch box. you should find sources there.
Leland
06-26-2005 14:40:27
Find a batterys plus or a battery store they can rebuild them as cheap as a new one if you can find one.
Unimog
06-26-2005 14:02:44
I had an 18volt build by these guys and it has
worked out real good.
www.primecell.com
