Tool Talk Discussion Forum
pneumatic needle scaler
Dave from Texas
06-23-2005 05:13:14
Yesterday's tip was using a pneumatic needler scaler to refurbish tractors. So I went and purchased one from Northern Tool last night ($39.95). It did not work to well on removing paint but it was OK for dirt and grim. Where I did find it useful was on had to reach places that the grinder wire wheel could not reach. What are your experiences? Is the cheap Northern Tool one typical? The lye gravey and wire wheel are hard to beat, but I keep trying to improve!
Dave
RustyFarmall
06-24-2005 07:51:56
 Re: pneumatic needle scaler in reply to Dave from Texas, 06-23-2005 05:13:14
Got mine from Northern tools, it's absolutely the best tool I have found for removing the 20 layers of paint that used to be on my M. I would not want to be without it.
Yes, the tractor does have at least 20 layers of paint. It was owned by a county roads dept. and was repainted every year.
Coldiron
06-23-2005 08:39:54
I have a Chicago Pneumatic that does a great job on thicker paint but is still good at thinner stuff. If you vary the distance of the needles from the target area you will find that it works better for a given thickness at certain angles and distances. Play with it and you will get it working at it`s optimum. HTH in some way.
Red Dave
06-23-2005 06:02:34
I have one and I like it. It's the cheap Northern Tool model too. Works great when there are several layers of paint built up or where there is a lot of rust. Gets in where a wire wheel won't go too. Doesn't work as well when the old paint is still good.
It's the old story, no one tool is best for every job. Sometimes a needle gun is best, sometimes a wire wheel is best, sometimes I sandblast. All depends on the situation.
lucasss
06-23-2005 05:34:20
i got a cp scaler and its good for removing slag from a weld,removing rusty scale from metals.it isnt really good for removing paint that isnt loose. lucass
