Tool Talk Discussion Forum
power washer hose fitting
Greg in milling
06-22-2005 19:20:33
I have a generac 2200psi power washer. the connecting threads on the pump that hooks up the spray wand has the first two threads pulled off when I removed the hose to replace the existing hose that was damaged. I can get it to start but as I try to tighten it it pulls off. Do they make quick connect fittings that I could put on the pump and hose end that might go all the way on or do they make an adapter for this problem?
Big Jim
06-23-2005 00:24:21
 Re: power washer hose fitting in reply to Greg in millington, 06-22-2005 19:20:33
Check out Northern Hydraulics - might be Northern Tools now. They have all kinds of that type of stuff.
