Tool Talk Discussion Forum
Rear End Ratios
Bacman48
06-21-2005 19:40:44
I have a '91 Dodge 150, 318 engine. The differential is bad. I have a differential out of a '91 Dodge 150 V6. Tag on the 318 reads 35.
Tag on the V6 reads 0734. Anyone know how to determine ratios? Thank you.
Charles (in GA)
06-22-2005 02:00:50
 Re: Rear End Ratios in reply to Bacman48, 06-21-2005 19:40:44
Count the teeth on the ring gear, and the pinion gear, and divide.
example: 12 teeth and 42 teeth equals 3.50 to 1.
Ford tags have the actual ration on the tag, don't know about Chrysler products.
Charles
txgrn
06-22-2005 04:33:10
 Re: Rear End Ratios in reply to Charles (in GA), 06-22-2005 02:00:50
Or get them out on a bench where you can make an accurate measurement. Mark the axle and drive shaft. Turn the drive shaft as many turns as necessary to cause the rear axle to make one complete revolution. That's your ratio. Being a differential, you will need to lock one shaft (so it can't turn); probably the left one would be better (driver's side).
Mark
Joe(TX)
06-22-2005 05:00:56
 Re: Rear End Ratios in reply to txgrn, 06-22-2005 04:33:10
Correction to Mark's reply:
If one wheel is locked, multiply the turns of the driveshaft by 2 for the ratio or make 2 turns of the wheel.
txgrn
06-22-2005 20:24:14
 Re: Rear End Ratios in reply to Joe(TX), 06-22-2005 05:00:56
I vaguely remember what you are talking about...vaguely. Remind me of the mechanism if you would.
Mark
Joe(TX)
06-23-2005 09:42:19
 Re: Rear End Ratios in reply to txgrn, 06-22-2005 20:24:14
The differential gears are the reason. If you turn one tire with the drive shaft held, the other tire turns in the opposite direction at the same speed. If you turn the drive shaft with one tire locked, the differential gears work to double speed the other tire, ie, they average the rotation speed.
txgrn
06-23-2005 14:37:08
 Re: Rear End Ratios in reply to Joe(TX), 06-23-2005 09:42:19
Ok. I guess if the guy did what I said and came out with a number like 7 or 8:1 he'd figure out that someting was wrong. Been awhile since I was into a differential.
Otherwise the thing to do would be to set up the two side by side and just compare them turn for turn without regard to counting.
Mark
