Tool Talk Discussion Forum
Yeah, that's why I though I'd ask before I did
Eddie in MI
06-21-2005 17:55:16
I know that I don't want it to lean out...
It's been a while since the machine has had a good "going-thru." I was just going to make sure that everything was nice and clean.
Rod: thanks for the link. I'm definitely gonna check that out.
As far as not running up top par, the machine idles nicely and it runs well at WOT, but it seems to get to full acceleration slowly, with some hesitation. Any ideas?
Rod (NH)
06-21-2005 19:56:01
 Re: Yeah, that's why I though I'd ask before I did in reply to Eddie in MI, 06-21-2005 17:55:16
As I remember, hesitation on acceleration indicates a main mixture that is slightly lean. If you have a high speed needle adjustment (usually indicated with an "H") and it is not already up against a limit stop, I'd try opening it a little. Say 1/8 turn or so to see if that helps. I'd avoid taking the carb apart if possible. If you do decide to take it apart, I'd advise having a rebuild kit available before you do.
Eddie in MI
06-21-2005 21:36:07
 Thanks! ntxt in reply to Rod (NH), 06-21-2005 19:56:01
ntxt
