Sears 6hp 30 gal compressor?
Brad Sparks
01-13-2001 21:22:13
I am looking at this compressor for $299. Would it be better to go with something smaller in an oil model? I only stain, paint and nail finish boards. Maybe a nailer someday. Thanks and also I have a 1hp/5gal oil compressor that finally seized after 20 years, do you think it is worth fixing?
ltf in nc
01-14-2001 19:16:15
 Re: Sears 6hp 30 gal compressor? in reply to Brad Sparks, 01-13-2001 21:22:13
If the unit is only 6+CFM, in reality it is only a 1 1/2HP unit regardless of the motor mounted on it. If you want a long lasting machine buy a belt drive and a lubed type. For value get the most CFM for the dollars spent. A decent compressor should make close to 4 CFM @ 90 psi per horsepower.
Brad S
01-14-2001 20:58:18
 Re: Re: Sears 6hp 30 gal compressor? in reply to ltf in nc, 01-14-2001 19:16:15
I decided to go with an oil unit a two cyclinder model with 6hp and a 25 gallon tank for $299. This pump is not the largest but should serve my needs. It puts out 6.5 cfm at 90. Thank you for all the input.
John in MA
01-14-2001 21:43:30
 Re: Re: Re: Sears 6hp 30 gal compressor? in reply to Brad S, 01-14-2001 20:58:18
Two cylinder single or two stage? Getting a two cyl, two stage is your best bet. They have great performance at higher pressures.
Also, this one would have to be one huge comressor to use a 6hp motor. LTF's computation is a good one.
Ray
01-14-2001 18:29:38
I have a 5hp 20 gal coleman - 5.6 CFM @ 90 psi. Sells for $199 at home centers. I saw the sears 6hp 30 gal - 6.2 CFM @90psi. They're both oil-less, essentially the same setup (mine's loud too) Not a big difference except price ! I like it fine for occasional use and I don't have to worry about an oil trap.
Ray
Jim K
01-14-2001 07:00:28
I'd be curious to hear others responses on this as I have an oiless compressor that has a busted con rod in my garage and I would like to upgrade to the IR 6hp 60 gal unit that SEARS sells.
Jim K
Scott Green
01-13-2001 23:26:16
Brad , Have them plug it in at the store , and listen to it run. If it is the one I think your talking about , you probably won't buy it. It is the loudest compressor I have ever herd. My uncle bought one. When it kicks on , you can not hear anything but that compressor. When I say loud , I mean LOUD.
Rod Mi
01-14-2001 10:05:10
 Re: Re: Sears 6hp 30 gal compressor? in reply to Scott Green, 01-13-2001 23:26:16
I have one of those oil lest air compressors from sears (6hp 60gal) I lick it for around the house but it is note a industrial model and I hade it for about 8 years with no problems I only use it on weak ends if noise is a concern at ALL do not by is very loud!!
Brad S
01-14-2001 07:44:53
Thanks Scott. I am going over to the store to pick it up today, so I will have them plug it in before I take delivery. If it is too loud then I will look for another model. Appreciate the input. My hearing is already somewhat suspect, so I cannot have one that is absolutely TOO LOUD.
