Tool Talk Discussion Forum
Karcher Power Washers
BrettW
06-20-2005 19:04:47
First time poster so bear with me. I was given a Karcher washer(gas) K 3300 G about 4 yrs ago...it was brand new used once. After using it once the pressure was gone. I took it to be repaired ($70), and it worked....once. It has sat in my garage staring at me since then. I have NEVER run hot water through this thing. Is there something that I can do repair wise to fix without taking it(again)to the shop. Help. Thanks.
Bob - MI
06-21-2005 05:19:54
 Re: Karcher Power Washers in reply to BrettW, 06-20-2005 19:04:47
Sounds like a stuck valve. If it was only $70.00 to repair it last ime, it couldn"t have been that tough of a fix (I"m guessing $20.00 in parts and $50.00 for labor). You could talk to the service guy and ask him if this is something you can repair. Once you get it going, I would use "pump saver" when you store it. It sounds like it is getting infrequent use and it will help.
You should be able to get it at Lowe"s and it"s available on-line at Jack"s Small Engines.
Good luck
