Tool Talk Discussion Forum
pressure washer Q- Ron From IL
Jay87T
06-20-2005 17:55:01
you told me a couple weeks back about that injector kit for the power washer you said it was a downstream one, you sure its not a upstream one you got from northern tool? the one that goes before the high pressure house for 30.00. this the one you are using? is downstream the garden hose side?
Ron from IL
06-21-2005 06:45:54
 Re: pressure washer Q- Ron From IL in reply to Jay87T, 06-20-2005 17:55:01
Jay,
Sorry it took so long to reply. I didn't "check in" until just now.
The pressure injector is, in fact, the one for $30 that fits just before the high pressure hose (downstream). Upstream is the garden hose side. It siphons the soap mix from a bucket via a small, clear tube (like fuel line). I've only used mine once (to clean my deck), but it really worked well. Like I said before, play around with your detergent mix, starting with a very WEAK one, because it REALLY foams up at that pressure! I didn't have to modify my nozzle to use it.
Good luck!
Ron
Van in AR
06-20-2005 22:03:29
Downstream is towards the wand, a downstream unit will put the soap in after the water pump allowing you to soap with high pressure instead of using low pressure. up stream would use the low pressure soap nozzle.
Van
Jay87T
06-21-2005 05:46:05
 Re: pressure washer Q- Ron From IL in reply to Van in AR, 06-20-2005 22:03:29
this is the upstream one. says it will apply the soap at high pressures like at the car wash...
Link
and this is the downstream one, says "Downstream injectors are installed after the pump. In order to function, the pressure must be lowered with the use of either a dual lance and soap nozzle"
http://www.jackssmallengines.com/barens_inject_ci.cfm
Ron from IL
06-21-2005 06:53:07
 Re: pressure washer Q- Ron From IL in reply to Jay87T, 06-21-2005 05:46:05
Jay,
I don't know why they would say one that a soap injector installed on the high-pressure side is an "upstream" one. If you think of the pressure washer as a river, where the water enters (hose) would have to be "upstream", since the water flows from the source to the mouth (downstream). So, closer to the outlet (high pressure end) would be "downstream". In my opinion, anyway...
Ron
