Tool Talk Discussion Forum
Auto darkening helmets (Again)
Hurst
06-19-2005 21:16:51
Today I was working on welding some bolts to a mowerdeck to hold down the shield for the belts when the ratcheting strap came apart when I adjusted it. This was a flip down cheapie helmet, so I was thinking of upgrading to an auto darkening from harbor freight that is $50. If I understand correctly, the reaction time is not going to hurt your eyes, just be like a camera flash if it is slow since the UV and IR rays are filtered out before darkening if it passes the ANSI standards? Also, is a 9-13 variable shade a good choice for AC arc welding with mostly 6011 rods? Viewing area will not be a big concern, I will just be doing some "farm welding". Thanks in advance for your help.
Hurst
rad
06-20-2005 12:45:07
 Re: Auto darkening helmets (Again) in reply to Hurst , 06-19-2005 21:16:51
I have a Harbor Freight auto darkening helmet and like it a lot. That said, it works very well when it is fairly light outside. If used in the evening or indoors, there is a pretty good sized flash before the photo cell gets enought light to power the darkener. So I only use their auto darkening during daylight hours. Teh next helmet will come from Miller or other commercial grade outfit.
Slowpoke
06-20-2005 23:30:04
 Re: Auto darkening helmets (Again) in reply to rad, 06-20-2005 12:45:07
My HF auto darkening helmet (OTOS Camilian W8000) will darken if I get a glint of sun off a chrome plated or other highly reflective object, or the sun itself. It's nowhere near the length of a camera flash before darkening. It's made in Korea and was about $150 on sale for $110 a couple of years ago. I've had no problems with it yet although it stays in the original box several weeks at a time, due to weather, time, etc. The only thing I don't like is that it is strictly solar charged. At a projected life of 5 years, they may be better and cheaper by then. Or I'll tear it apart and put in new batteries, like I did with my Sonicare toothbrush.
Jerry A.
06-20-2005 12:38:38
Autodarkening helmets are one of man's greatest inventions. Both of mine came from Harbor Fright...and work just fine. Paid about $98 and $58 dollars respectively.
I do hobby welding and couldn't justify $250-300 for a helmet.
M.Johnson
06-20-2005 06:27:45
I also have this helmet, that I use for Tig welding on night shift at an Airline. Will not work with inverter type welders!
txbrn
06-20-2005 04:58:41
Probably the same one I bought from them. Love it. Can adjust reaction speed and yes it is fast enough.
Mark
TimV
06-20-2005 03:59:19
Hurst: I"ve got one and have had no troubles in a year or so of fairly frequent use. It"s helped my welding a lot, and I would definitely recommend one to anyone who doesn"t weld all-day-every-day.
BFO
06-20-2005 03:36:56
Your eyesight is worth more than $50. Maybe if no one bought that crap from harbourfrieght they would stop selling it. Spend the money and buy a Speedglass. I had a cheapie, eyesight went from 20/20 to 20/30. When I hire a welder, and he makes probation, I buy a Speedglass, less welder fatigue and absentee-ism.
old
06-19-2005 21:33:55
I have used them before and also ended up in the hospital because of them, with my eyes burned. I will never us one again. I use only gold lens I believe they are 24 carat gold, haven't ever had a problem agin sine I have been useing them. And I do weld a lot, just last week went through 10 lbs of rod in 2 days.
Bobg
06-20-2005 06:34:25
 Re: Auto darkening helmets (Again) in reply to old, 06-19-2005 21:33:55
I have one that I think is a SpeedAire. I wouldn't trade my for anything, well almost anything. For doing delicate work or to get things tacked in place you can't beat them. I still like my old helment that has the large glass in it though you can see quite a bit of area.
Bobg
