Tool Talk Discussion Forum
bubbles in weld
Lori
06-19-2005 15:11:49
Can someone tell me why there are pinholes in the bead when I weld? Just a beginner so I am confused. Looks like weevils got to it.
Thanks
Mike M
06-20-2005 03:37:13
 Re: bubbles in weld in reply to Lori, 06-19-2005 15:11:49
I can add one more thing that the others didn't.
I had that problem with 7018 rods made for use with AC I never could get good results with them on AC so I use another welder with DC and have far better results.
Stan in Oly, WA
06-19-2005 19:24:25
Hi, Lori
A few more things that can produce porosity are: moisture contaminated low hydrogen rods (7018 is the most common, but 7016, 7028, 8018, 9018, etc. are also low hydrogen rods.) These rods must be kept in a rod oven once they have been removed from the sealed container in which they were purchased.
The beginning of a bead on cold metal will sometimes show a bit of porosity which the remainder of the bead, on hot metal, does not.
Also, lifting the rod straight up at the end of a bead will often cause a single, crater like hole, though this is not what you are describing.
Dr. Sportster assumed you were asking about SMAW since buzz boxes have been the standard equipment for entry level welders, but maybe you are using wire feed. Prices on low powered and/or no name units have certainly put them within most people's reach.
The most common cause of porosity with GMAW is inadequate shielding gas. Either the gas pressure is adjusted too low, the gas is being blown away by air movement (like wind or a fan), or there is a more complicated problem in the gas delivery part of the system. You can aim the wire feed gun at your bare hand, pull the trigger to feel the gas, and still have time to get your hand out of the way before the wire hits it. That's the real world way to find out if gas is coming out of the nozzle. I don't know what the OSHA approved way is.
All the best, Stan
Stan Lewis
06-20-2005 07:42:43
 Re: bubbles in weld in reply to Stan in Oly, WA, 06-19-2005 19:24:25
Hi, Lori
I have to correct myself. I did some research after my first post; a far more authoritative source than myself stated flatly that dirty metal is the number one reason for porosity with wire feed welding. Essentially the same as the good advice you are getting about porosity from stick electrodes.
What I should have said is that I personally experienced porosity from lack of shielding gas when wire feed welding, making it the number one problem in my limited experience. That's actually quite different, isn't it.
All the best, Stan
old
06-19-2005 16:10:35
There are a lot of things that can cause that. The main one being dirty metal. When you weld you should use a grinder on the metal first to remove rust, paint and other things that cause that.
dr.sportster
06-19-2005 16:02:50
Assuming you mean arc welding;wrong rod angle,oily metal,moisture in rod,moisture formed by making the steel change temp[no preheat].Cant think of them but there is probably a few others.
Davis In SC
06-19-2005 20:30:31
 Re: bubbles in weld in reply to dr.sportster, 06-19-2005 16:02:50
Dr.S one thing you left out, weevils might be eating holes in the welding rods.... No offense, just some good-natured humor... 8^)
dr.sportster
06-20-2005 12:35:54
 Re: bubbles in weld in reply to Davis In SC, 06-19-2005 20:30:31
That one was not mentioned.Good call.
