Tool Talk Discussion Forum
What's wrong with my welder?
R. John Johnson
06-18-2005 10:08:54
I have a Century Buzz Box welder. There are two plugs for the electrode holder cable, marked high and low. The amperage is set by a lever and clamp on the front of the welder. Squeeze the clamp handle and slide the lever up and down to the desired amperage and release the clamp. My problem is this. No matter where you set the amperage it slides down to a lower setting It returns to this setting no matter how high you set it initially. Chosing high or low plugs makes no difference. I had been using the welder to weld 1 x 1 x .100 tubing on bale feeders this winter and the setting was perfect. It was just today I went to weld something heavier and found the problem. Any help would be appreciated.
John
fred kobs
06-18-2005 16:05:00
 Re: What's wrong with my welder? in reply to R. John Johnson, 06-18-2005 10:08:54
I had a Century but not that model. It had a rod to pull then adjust, lock w/rod. It got kinda rusty inside the case. After opening it up, took a few min. to figure out the design, then some pen. oil and a screwdriver was all it took HTH Fred
R. John Johnson
06-18-2005 18:14:49
 Re: What's wrong with my welder? in reply to fred kobs, 06-18-2005 16:05:00
I took the cover off and peeked inside. There are two bars that slide up and down. A spring forces them to clamp together when the handle is released. Tightening up the spring did not help.
John
DennisW
06-21-2005 20:12:56
 Re: What's wrong with my welder? in reply to R. John Johnson, 06-18-2005 18:14:49
This is a common enough problem. You can try to tighten the nut on the shunt to increase the spring tension, although this rarely works in my experience. The part number for a new shunt assy is 860-402-666, about $53 plus shipping. Call me at 800.925.7741 if you are interested.
