Tool Talk Discussion Forum
Spot Resurfacing Concerete
wsmm
06-18-2005 09:30:58
The concerete in my pole barn, has done what I call scaling. It was suppposed to be a smooth finish, but in many areas part of it has flaked off leaving rough stones, etc. I don't want to resurface the whole thing with a inch or so, because I need all the ceiling height I have now. What could I use to fill in and level these areas, some are really small others are fair in size.
Thanks
Bill
ScottP
06-19-2005 18:24:43
 Re: Spot Resurfacing Concerete in reply to wsmm, 06-18-2005 09:30:58
Bill
I work in a 800,000sqft warehouse that was built in the late 70s'. I have been doing a lot of floor repairs for the last 15 years. I have used tar, epoxy fillers, thinset concrete patch and poly based epoxy fillers. They all work, they just very in price.
I can tell you this, If you dont prep the floor right your patch will NEVER stay.
Get a diamond crack chasing blade that goes on an angle grinder and outline the area to be patched. Make the grove at least a 1/4" deep, then chip out the area down to clean white concrete. Clean up the hole with a broom, then vaccum the area twice. It is VERY VERY important to get up all the dust for a proper bond. Then mix and pore your filler.
Scott
Bus Driver
06-19-2005 05:27:12
This method is not cheap, but in my basement, we had to move an interior wall that had been nailed down to the concrete. The nail spots in the concrete were patched with JB Weld and then sanded smooth with a disc sander. Blends in remarkably well. Thorough removal of loose chips and vacuuming is vital before applying the JB.
greenbeanman in Kansas
06-19-2005 05:07:02
You have been given lots of choices. If the remaining concrete is no longer flaking you could also use fiberglass body putty.
The reason I mention it is that I was reading the directions on a can yesterday and they specifically mentioned concrete repair. Who knew?
Vern-MI
06-18-2005 16:13:34
Quikrete "Concrete Resurfacer"
Vern-MI
06-18-2005 16:09:41
CTS Cement "Rapid set"
dr.sportster
06-18-2005 12:47:02
The product might be called Ardex.Self leveling, pours real thin without breaking.
MAC,IL
06-18-2005 13:55:16
 Re: Spot Resurfacing Concerete in reply to dr.sportster, 06-18-2005 12:47:02
Sportster. CRS anymore, but what we mixed was pretty much liquid. Mixed stuff that looked like milk with powder and you had a decent working time before it set up. We set machinery mounting bolts in the floor and poured it around the bolt. it is still there as far as I know.
MAC,IL
06-18-2005 10:27:24
years ago the place I worked, we used an epoxy type filler and worked really good. The name escapes me now. Got a senior moment. But check this out and maybe it will give you a better idea.
Link
Dean K.
06-18-2005 20:20:39
 Re: Spot Resurfacing Concerete in reply to MAC,IL, 06-18-2005 10:27:24
Loctite has a new product out called magnacrete, they've been getting in lately at work. It really seems to stick, still in place where epoxy had popped out. It's a powder and a green liquid that looks like antifreeze, it's not fussy about the mix ratio, enough liquid to get the consistency you want. I think they get it thru fastenal, no affiliation with either, just impressed with the product. DK
