Tool Talk Discussion Forum
Karcher power washers
Jay87T
06-17-2005 14:46:56
anyone know where these are made? Im thinking of buying a electric one but I want to know where its made first, My last power washer was a simonz and Im not pleased with that at all, was made in italy I think (you`d think it be good being built there"
the plastic valves in that power washer craped out and I had no pressure.
Karchers OK
06-18-2005 12:21:07
 Re: Karcher power washers in reply to Jay87T, 06-17-2005 14:46:56
I work with Karcher washers at work all the time. They work good and are very dependable UNTIL some numb skull runs HOT water through them. Hot water kills the valves every time(Yes, they are plastic).
BrettW
06-20-2005 19:03:35
 Re: Karcher power washers in reply to Karchers OK, 06-18-2005 12:21:07
First time poster so bear with me. I was given a Karcher washer(gas) K 3300 G about 4 yrs ago...it was brand new used once. After using it once the pressure was gone. I took it to be repaired ($70), and it worked....once. It has sat in my garage staring at me since then. I have NEVER run hot water through this thing. Is there something that I can do repair wise to fix without taking it(again)to the shop. Help. Thanks.
Galen
06-18-2005 07:01:34
Made in Germany. Not sure what model, but my sister made a lot of money with one.
bill b va
06-17-2005 22:02:29
karecher washers are all plastic junk . my first one started leaking and i took it to the authorized service center while under warrenty . they had whole pile of them . said they were not going to take any more as they were having problem gettig paid for the repairs by karcher .took it back to lowes and they gave me another when i explained the problem warrenty. second one quit working . i took the pump apart and the plastic pistons were shot .every thing plastic
bill b va
06-17-2005 21:58:19
buickanddeere
06-18-2005 09:25:44
 Re: Karcher power washersGas Pressure Washers: Pro in reply to bill b va, 06-17-2005 21:58:19
Gas Pressure Washers: Prosumer Part Number Operating Pressure Power Supply Water Volume � G 2600 OR
1.194-506.0 2600 PSI 6.0 HP Subaru EX-17 2.6 GPM, Direct-Drive Axial Pump
� G 2650 HH
1.194-508.0 2650 PSI 6.0 HP Honda GC 190 2.6 GPM, Direct-Drive Axial Pump � G 2800 OH
1.194-510.0 2800 PSI 6.0 HP Honda GC 190 2.6 GPM, Direct-Drive Axial Pump � G 3000 OH
1.194-509.0 3000 PSI 6.0 HP Honda GC 190 2.5 GPM, Direct-Drive Axial Pump
Gas Pressure Washers: Professional Part Number Operating Pressure Power Supply Water Volume � HD 3000 DH
1.187-116.0 3000 PSI 9.0 HP Honda GX 270 3.1 GPM, Direct-Drive Axial Pump � HD 3600 DH
1.810-934.0 3600 PSI 13.0 HP Honda GX 390 4.0 GPM, Direct-Drive Axial Pump Portable Gasoline Engine HD Classic Gasoline This series of commercial-duty, gas-powered cold water pressure washers offers the ideal balance between professional performance and value... HD Liberty Gasoline Liberty Series HD P models are tough gas-powered directdrive cold water machines that deliver cleaning power of up to 3500 PSI. Built on compact sturdy steel frames... Portable Electric Motor HD Classic Electric K�rcher's Classic Series electric powered cold water units are compact, highly mobile and hard wearing. Built with high grade lightweight polypropylene and designed with usability and ergonomics in mind... HD Liberty Electric Our HD Ed machines are durable direct-drive electric powered units that can deliver cleaning volume of up to 3.5 GPM. Powered by heavy duty... Hand-Held HD Hand Held Electric These light-industrial electric hand held units are significantly more rugged and reliable than typical consumer substitutes and are built with powder coated steel frames. HD Hand Held Gasoline This gas powered hand held unit delivers up to 2400 PSI with the added independence afforded by a reliable Honda engine. Beats me why you bought a cheapo? Have a look at the Prosumer and better pressure washers. For a few more bucks you would have had an outstanding machine with cleaning power and durability. The premium axials will handle water up to 100F. The ceramic piston models will take what ever your home hot water heater will produce.
buickanddeere
06-17-2005 23:39:58
 Re: Karcher power washers in reply to bill b va, 06-17-2005 21:58:19
If you purchase a cheap machine and run hot water through it, yes it will fail. Most manuafctures do make a p.o.s. "price shopper" machine. There are customers who look only for the cheapest purchase price. Rather than considering cost per hour usage and cost of down time. Spend a little more for the Karecher with the CAT or Comet three piston brass and ceramic pump. It's like comparing paper dinner plates to Corel Dinner Ware.
Jay87T
06-17-2005 15:57:38
Also looking at some power washers, they are like no name brands like Power XT, but they look just like Karcher power washers, can these be Karchers but with a no name brand on them???
36BinMN
06-17-2005 16:27:58
 Re: Karcher power washers in reply to Jay87T, 06-17-2005 15:57:38
I have a Karcher model, K 2.45, It"s made in Germany. Mine is elec. 1400 PSI. I prolly have two hundred hours on it and not a problem yet!!! I am very happy with it and the price was about $130.00. If you do get an electric model hook up the water hose and let the water run out of the hook up for the wand to get ALL the air out of the hose and pump before you start it up!!!
