Tool Talk Discussion Forum
Yo, Mr. T-Bone (or other welders) Help, please.
Tom in TN
06-12-2005 10:48:01
T-Bone,
I talked to you about this a while back, and checked out some things you mentioned. I still can't weld. Here's my deal. I have a Century 115 volt wire-feed welder. I do not have the MIG attachment so I'm using .030 flux core wire. I'm trying to weld some 1/8" mild steel angle iron. The welder is five years old and has always acted the same every time I've tried to use it. It is set to DC minus (as it is specified on the welder for flux core wire), and the wire is exactly what the welder specifies should be used.
When I try to strike an arc, the wire immediately melts into a little ball of weld and doesn't get the metal hot enough to bond it. I've tried every combination of slow and fast wire feed, high and low voltage, etc., and they all produce the same results.
If I were stick welding, I'd get a bigger rod and let it melt the metal, but the wire just flashes as soon as it touchs the metal.
The wire is five years old. I've kept the welder in a dry shed, but it's not humidity controlled.
Do you have any suggestions?
Thanks,
Tom in TN
Trucker
06-16-2005 22:25:34
 Re: Yo, Mr. T-Bone (or other welders) Help, please in reply to Tom in TN, 06-12-2005 10:48:01
Squeeze the trigger and watch the wire without trying to weld,does it stop?Does your welder have a knob for stitch welding?Is it anywhere besides off?IF the answer is no to all that,try welding the ground clamp to the work first,also those little welders need the metal to be clean,no paint or rust to make a decent weld,it most likely wont weld thru rust or paint at all,doesnt have the amps.Another thing is it sounds kind of like the wire might be too big for the heat you are using,but unless I saw what it did I wouldnt know.
Loren
06-13-2005 19:08:07
Sure sounds to me that you need to increase wire feed or lower the amps. Don"t change the amp setting while welding, usually bad for the machine. Try turning the wire feed up till it trys to push the wand back when you strike an arc, then back it down a bit at a time. If you can"t get the wire to push the wand back you may have a problem there. First thing in that case seems to be too small a wire for the amps. My little 110 mig sees a BIG difference in how it welds when using it straight out of the wall or through an extension cord. That line voltage loss really shows up. If you"re on a 100 cord maybe try eliminating that too.
dixie
06-12-2005 18:23:06
Most flux-core wire spools oxidize to the point of being worthless in about a year or so after you put them in the machine. I keep silica gel packets inside the cover of my Century unit when it's in storage. Good Luck
T_Bone
06-12-2005 18:06:33
Hi Tom,
I think I remember something about it but I'll give you my Mig list of what to check. Start there then we'll see where your at.
First check the tip to make sure it's feeding wire free.
Next check the liner to see if it's clean and not binding.
Next check the liner feed tip to make sure it's not grooved and the wire hanging up there.
Next take the drive rolls off and cut off a small piece of wire and place it between the rolls grooves while holding upto the sunlight and if the drive roll faces are touching then the wire gooves are worn and the drive rolls needs replaced. Some drive rolls have two different grooves for different wire sizes and make sure they match wire size when you reinstall them. They will be stamped for the correct wire size on the edge of the drive roll.
Next check the tennsion on the wire spool. It should be firm but not hard when trying to unspool wire. The center nut adjusts the spool tennsion. If it binds or won't spool off smoothly then clean the wire spool drive tennsion adjustment.
If the wire has rust or other forgien material either clean the wire or replace it. Also watch for the wire crossing over another wire causing binding.
Always check the ground clamp for a good connection. Move the clamp as close too the weld zone as possible to remove any doubts.
T_Bone
BFO
06-12-2005 16:48:11
sounds like your voltage is too high for the wire speed.
jhill
06-12-2005 18:56:57
 Re: Yo, Mr. T-Bone (or other welders) Help, please in reply to BFO, 06-12-2005 16:48:11
I agree with BFO that but it may be caused by slow feed rate do T-Bones checks on tension and binding.
lucasss
06-12-2005 11:43:44
i been talkin to lincoln this week because im goin to get a mig from them . they told me that many economy priced welders advertise they will weld up to 1/4 inch , BUT ,barely (sometimes dont) have the amps to do it ,and only run 20% duty cycle on the high setting.that means you can weld 2 minutes out of 10 before welder has to cool off. now i know i didnt answer your question , but if your welding thinner stuff ok with it you may be asking to much out of it. lucas
