Tool Talk Discussion Forum
Got my new press--oh boy
John in MA
06-11-2005 21:04:01
I had asked about buying a new 12-ton cheapie import press a while back. Mainly because of budget limitations. The advice offered was to go a little bigger.
Think this qualifies?! Found it for $120. Made in 1944 (war production!), weighs 850 pounds, made out of 3/4" and 1" steel, stands 76" tall and 46" wide. It's a KR Wilson with a 3-ton mechanical feed, and a 2-speed hydraulic pump that'll give you 25 tons of squish. Probably could go a lot higher in a pinch.
Had to take it apart to move it, and right now it's in a pile in the basement. What a bear. Here's the "before" photo in the fellow's garage:
third party image
Davis In SC
06-12-2005 18:52:25
 Re: Got my new press--oh boy in reply to John in MA, 06-11-2005 21:04:01
That press is a fine example of the what has happened to our country & economy... in only 50 or so years, we have gone from being the king of Design & Maufacturers, to being buyers of junk from China. Just look at that press... With a little care, it should last for hundreds of years... The China Crap we get today is only good for a few years. Cheaper is not always better..... Sad thing is, Companies thar built good products are all out of business now....
T_Bone
06-12-2005 18:12:07
Hi John,
Geez you made a better find than me. I'd give up what I got for your press if that would be of interest....lol
T_Bone
John in MA
06-12-2005 20:23:17
 Re: Got my new press--oh boy in reply to T_Bone, 06-12-2005 18:12:07
OK, I'll bite. What'd you score?
T_Bone
06-13-2005 00:03:42
 Re: Got my new press--oh boy in reply to John in MA, 06-12-2005 20:23:17
Hi John,
In a bag, Old Starret 2" to 3" Mic, 3" to 4" Mic, 1-1/2" dial indicater with mag base, 2-center finders (new), $40
Two portapowers, 2ton, 4ton with 6 heads, 5"x24" hydraulic cyl (new), $60
6" Eaton bench vise, $20
Makita screw gun (used twice), 1-1/4" Air brad nailer, 2 chain vise grips (new in package), $40
7- 3/4" pipe clamps with pipe, $20
4ton hand winch, the old heavy style with 50' 3/8" cable, $10
80lbs of 6011, 7018, 308L, 309L $20, I missed the Miller Tig welder and Bobcat machines. Sold last year for a $1000, looked like new.
22 commerical units, 36"wide x 18" deep x 7ft-6" steel storage shelves with 5 steel shelves each unit, $150
1000lbs of misc new steel, $50
T_Bone
Vern-MI
06-12-2005 16:48:54
Nice press! What is the four bar hand crank on the right side used for? Is it a means of adjusting a threaded ram extension for initial contact?
John in MA
06-12-2005 16:57:08
 Re: Got my new press--oh boy in reply to Vern-MI, 06-12-2005 16:48:54
The crank has a pinion gear on the end, and the ram has a rack directly machined into it. It'll act as a sensitive 3-ton manual press with that.
Still need to sort some things out. The ram is _really_ hard to move manually. Hope it's just crud and not bent.
Davis In SC
06-12-2005 15:10:44
Nice Press !!! That rigid ram is much safer than the cheap new presses. Those new ones will kick off center & throw the workpiece out . A friend was badly injured that way last year. You got a great deal on a fine press. It is a shame that stuff is not built like that now..... .
Charles (in GA)
06-12-2005 14:25:06
Congratulations, excellent find. The Wilson press is a jewell of a press, as it acts as an arbor press with the cross handle on the right, and as a hydraulic press also.
Go to this link for parts info and the manuals on these old presses, you can download.
Link
BKahler
06-12-2005 05:05:24
I like it! Wish I could find one like that!!!!
Brad
Aussirtractor
06-12-2005 00:14:27
John, It looks like you have got a good old press and haven't paid to much for it either. Did it come with its press plates? It will still be around in another 60 years if looked after.Well done
